Date/Time: Mon, 06 Jan 2025 09:42:29 +0000
Disable Trade Quantity Change Feature In Region Line 1
View Count: 728
[2016-06-22 06:19:29] |
User948528 - Posts: 108 |
How can I disable the trade quantity change option in chart region line 1? I often hit it by accident.
[2016-06-22 06:21:30] |
There is not a way to do this.
[2016-06-22 06:25:50] |
Thanks, please consider allowing this to be disabled, it is unnecessary with the same option in the trade window, and an inconvenience and risk when hit by accident.
[2016-06-22 06:35:20] |
As you are already aware, even when you click that quantity number you still have to manually change the quantity and press OK to actually change it.
