Date/Time: Tue, 07 Jan 2025 20:52:34 +0000
Better Volume Study Bug
View Count: 1674
[2016-06-22 02:09:09]
User948528 - Posts: 108
Since this is a custom study packaged with SC, if SC cannot help, could you provide the contact info for the SC user 'jsyd' who contributed it?
When settings are set as YES to Color Bars on price, and NO to Only Paint signals on bar close, future price bars are painted with the Low Volume signal, even if they are not Low Volume bars.
A Chart Reload/Recalculate re-draws the past bars correctly, but future bars continue to paint incorrectly. This only occurs on painted color bars, not the volume histogram.
Date Time Of Last Edit: 2016-06-22 03:20:18
[2016-06-27 22:43:20]
Can anyone help with this, or at least with the contact info for user jsyd on the old support board?
[2016-06-28 17:20:33]
We will see if we can correct this problem ourselves. Just give us a chance.
[2016-07-01 06:15:03]
Thank you, would be much appreciated if you could look at this soon.
Also it would be useful to be able to contact users on the support board, at least by request, it may reduce your attention needed.
[2016-07-01 06:28:17]
We are not going to be able to get to this.
We do not have time to track down that user. We also do not believe this is a reasonable approach to the problem anyway.
We can provide you the source code for the study if you want to look at it.
Date Time Of Last Edit: 2016-07-01 06:28:51
[2016-07-01 06:58:08]
The reason we are not going to be able to get to it, is because as usual, we keep getting very overwhelmed with other higher priorities and just do not have a chance to get it.
You can find the source code for it here:
User Contributed Advanced Custom Study System Source Code
