Date/Time: Mon, 06 Jan 2025 10:07:01 +0000
CCI predictor
View Count: 1068
[2016-06-21 19:34:16] |
User533143 - Posts: 14 |
I followed instructions( range bar in ticks, cci and predictor with similar settings) ; but still get up and down arrows showing together-been tinkering-but can't figure it out.
[2016-06-22 06:13:32] |
We did a quick test and it does work properly. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
