Date/Time: Mon, 06 Jan 2025 09:46:12 +0000
I draw a horizontal line at 1.4 in Daily chart of USDCAD, why it also shows on GBPUSD?
View Count: 703
[2016-06-21 15:51:08] |
User349605 - Posts: 11 |
Hello, I don't know if I do something wrong. As title, I draw a horizontal line at 1.40000 in Daily chart of USDCAD, and then I find it shows on GBPUSD as well. How come? Can I disable this link relationship? Please help, thanks. Fanhow Date Time Of Last Edit: 2016-06-21 15:53:06
[2016-06-21 17:33:17] |
You need to uncheck Chart >> Chart Settings >> Advanced Settings 2 >> Show Chart Drawings for Different Symbols: http://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-23 01:54:13] |
Thanks a lot!
