Date/Time: Mon, 06 Jan 2025 09:46:27 +0000
cannot sign in
View Count: 763
[2016-06-21 15:45:31] |
User157921 - Posts: 2 |
I can not log in.Igetthe foll messages----waiting to reconnect and connecting.Thanks Hasnain |
[2016-06-21 16:16:52] |
Sierra Chart - Max - Posts: 5775 |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support |
[2016-06-21 16:20:06] |
Reading Internal Order ID file. | 2016-06-21 15:20:13 Reading Trade Orders file. | 2016-06-21 15:20:13 Reading Trade Positions file. | 2016-06-21 15:20:13 Software version: 1426 | 2016-06-21 15:20:13 Uses New Spreadsheets | 2016-06-21 15:20:13 Usage end date: 2016-07-05 | 2016-06-21 15:20:13 Enabled for: Advanced Features. | 2016-06-21 15:20:13 Enabled for: Advanced Features 2. | 2016-06-21 15:20:13 Enabled for: Sierra Chart Historical Data Service. | 2016-06-21 15:20:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-06-21 15:20:13 Current selected Data/Trading service: GAIN Capital/OEC | 2016-06-21 15:20:13 Chart Update Interval: 500 | 2016-06-21 15:20:13 Time Zone: +00:00:00 (UTC+00) | 2016-06-21 15:20:13 2016-06-21 11:20:20 Local computer time | 2016-06-21 15:20:13 2016-06-21 15:20:20 Local computer time in UTC | 2016-06-21 15:20:13 2016-06-21 15:20:20 Local computer time in SC Time Zone | 2016-06-21 15:20:13 2016-06-21 15:19:58 Server time in UTC | 2016-06-21 15:20:13 Local computer UTC time and Server UTC time difference: 21 seconds. | 2016-06-21 15:20:13 Program path: C:\SierraChart\ | 2016-06-21 15:20:13 Data Files path: C:\SierraChart\Data\ | 2016-06-21 15:20:13 OS Version Number: 6.1 | 2016-06-21 15:20:13 Locale Setting: C | 2016-06-21 15:20:13 Checking for new symbol settings for oec | 2016-06-21 15:20:13 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-21 15:20:13 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-06-21 15:20:13 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-06-21 15:20:13 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-06-21 15:20:23 Symbol settings are up-to-date for oec | 2016-06-21 15:20:24 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:25 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:26 GainCapital FIX Trading socket (4) | Connected. | 2016-06-21 15:20:26 GainCapital FIX Trading socket (4) | Starting TLS 1.2 connection. | 2016-06-21 15:20:26 GainCapital FIX Trading socket (4) | SSL connection established. | 2016-06-21 15:20:28 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:28 GainCapital FIX Trading socket (4) | Closed. No error. | 2016-06-21 15:20:28 GainCapital FIX Trading socket (4) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:28 GainCapital FIX Trading socket (4) | SSL has been shut down. | 2016-06-21 15:20:28 GainCapital FIX Trading socket (4) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:28 GainCapital FIX Trading socket (4) | Shutdown and closed. | 2016-06-21 15:20:28 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:28 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:28 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:20:28 GAIN Capital/OEC | Disconnected from the FAST market data server. | 2016-06-21 15:20:28 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:28 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-06-21 15:20:29 HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-06-21 15:20:29 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:29 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-06-21 15:20:29 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:31 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:31 GainCapital FIX Trading socket (5) | Connected. | 2016-06-21 15:20:31 GainCapital FIX Trading socket (5) | Starting TLS 1.2 connection. | 2016-06-21 15:20:31 GainCapital FIX Trading socket (5) | SSL connection established. | 2016-06-21 15:20:32 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:32 GainCapital FIX Trading socket (5) | Closed. No error. | 2016-06-21 15:20:32 GainCapital FIX Trading socket (5) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:32 GainCapital FIX Trading socket (5) | SSL has been shut down. | 2016-06-21 15:20:32 GainCapital FIX Trading socket (5) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:32 GainCapital FIX Trading socket (5) | Shutdown and closed. | 2016-06-21 15:20:32 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:32 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:32 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:32 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:35 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:35 GainCapital FIX Trading socket (6) | Connected. | 2016-06-21 15:20:36 GainCapital FIX Trading socket (6) | Starting TLS 1.2 connection. | 2016-06-21 15:20:36 GainCapital FIX Trading socket (6) | SSL connection established. | 2016-06-21 15:20:36 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:36 GainCapital FIX Trading socket (6) | Closed. No error. | 2016-06-21 15:20:37 GainCapital FIX Trading socket (6) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:37 GainCapital FIX Trading socket (6) | SSL has been shut down. | 2016-06-21 15:20:37 GainCapital FIX Trading socket (6) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:37 GainCapital FIX Trading socket (6) | Shutdown and closed. | 2016-06-21 15:20:37 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:37 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:37 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:20:37 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:37 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:40 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:40 GainCapital FIX Trading socket (7) | Connected. | 2016-06-21 15:20:41 GainCapital FIX Trading socket (7) | Starting TLS 1.2 connection. | 2016-06-21 15:20:41 GainCapital FIX Trading socket (7) | SSL connection established. | 2016-06-21 15:20:45 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:45 GainCapital FIX Trading socket (7) | Closed. No error. | 2016-06-21 15:20:45 GainCapital FIX Trading socket (7) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:45 GainCapital FIX Trading socket (7) | SSL has been shut down. | 2016-06-21 15:20:45 GainCapital FIX Trading socket (7) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:45 GainCapital FIX Trading socket (7) | Shutdown and closed. | 2016-06-21 15:20:45 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:45 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:45 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:45 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:45 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:48 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:48 GainCapital FIX Trading socket (8) | Connected. | 2016-06-21 15:20:48 GainCapital FIX Trading socket (8) | Starting TLS 1.2 connection. | 2016-06-21 15:20:48 GainCapital FIX Trading socket (8) | SSL connection established. | 2016-06-21 15:20:49 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:49 GainCapital FIX Trading socket (8) | Closed. No error. | 2016-06-21 15:20:50 GainCapital FIX Trading socket (8) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:50 GainCapital FIX Trading socket (8) | SSL has been shut down. | 2016-06-21 15:20:50 GainCapital FIX Trading socket (8) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:50 GainCapital FIX Trading socket (8) | Shutdown and closed. | 2016-06-21 15:20:50 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:50 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:50 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:20:50 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:50 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:53 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:53 GainCapital FIX Trading socket (9) | Connected. | 2016-06-21 15:20:53 GainCapital FIX Trading socket (9) | Starting TLS 1.2 connection. | 2016-06-21 15:20:53 GainCapital FIX Trading socket (9) | SSL connection established. | 2016-06-21 15:20:53 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:54 GainCapital FIX Trading socket (9) | Closed. No error. | 2016-06-21 15:20:54 GainCapital FIX Trading socket (9) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:54 GainCapital FIX Trading socket (9) | SSL has been shut down. | 2016-06-21 15:20:54 GainCapital FIX Trading socket (9) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:54 GainCapital FIX Trading socket (9) | Shutdown and closed. | 2016-06-21 15:20:54 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:54 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:54 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:54 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:20:57 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:20:57 GainCapital FIX Trading socket (10) | Connected. | 2016-06-21 15:20:57 GainCapital FIX Trading socket (10) | Starting TLS 1.2 connection. | 2016-06-21 15:20:57 GainCapital FIX Trading socket (10) | SSL connection established. | 2016-06-21 15:20:58 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:20:58 GainCapital FIX Trading socket (10) | Closed. No error. | 2016-06-21 15:20:58 GainCapital FIX Trading socket (10) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:20:58 GainCapital FIX Trading socket (10) | SSL has been shut down. | 2016-06-21 15:20:58 GainCapital FIX Trading socket (10) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:20:58 GainCapital FIX Trading socket (10) | Shutdown and closed. | 2016-06-21 15:20:58 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:20:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:20:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:20:58 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:20:58 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:20:58 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:20:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:20:58 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:01 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:01 GainCapital FIX Trading socket (11) | Connected. | 2016-06-21 15:21:01 GainCapital FIX Trading socket (11) | Starting TLS 1.2 connection. | 2016-06-21 15:21:01 GainCapital FIX Trading socket (11) | SSL connection established. | 2016-06-21 15:21:02 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:21:02 GainCapital FIX Trading socket (11) | Closed. No error. | 2016-06-21 15:21:02 GainCapital FIX Trading socket (11) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:21:02 GainCapital FIX Trading socket (11) | SSL has been shut down. | 2016-06-21 15:21:02 GainCapital FIX Trading socket (11) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:21:02 GainCapital FIX Trading socket (11) | Shutdown and closed. | 2016-06-21 15:21:02 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:21:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:21:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:21:02 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:21:02 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:21:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:21:02 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:05 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:05 GainCapital FIX Trading socket (12) | Connected. | 2016-06-21 15:21:06 GainCapital FIX Trading socket (12) | Starting TLS 1.2 connection. | 2016-06-21 15:21:06 GainCapital FIX Trading socket (12) | SSL connection established. | 2016-06-21 15:21:06 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:21:06 GainCapital FIX Trading socket (12) | Closed. No error. | 2016-06-21 15:21:07 GainCapital FIX Trading socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:21:07 GainCapital FIX Trading socket (12) | SSL has been shut down. | 2016-06-21 15:21:07 GainCapital FIX Trading socket (12) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:21:07 GainCapital FIX Trading socket (12) | Shutdown and closed. | 2016-06-21 15:21:07 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:21:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:21:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:21:07 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:21:07 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:21:07 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:21:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:21:07 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:10 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:10 GainCapital FIX Trading socket (13) | Connected. | 2016-06-21 15:21:10 GainCapital FIX Trading socket (13) | Starting TLS 1.2 connection. | 2016-06-21 15:21:10 GainCapital FIX Trading socket (13) | SSL connection established. | 2016-06-21 15:21:21 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:21:21 GainCapital FIX Trading socket (13) | Closed. No error. | 2016-06-21 15:21:22 GainCapital FIX Trading socket (13) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:21:22 GainCapital FIX Trading socket (13) | SSL has been shut down. | 2016-06-21 15:21:22 GainCapital FIX Trading socket (13) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:21:22 GainCapital FIX Trading socket (13) | Shutdown and closed. | 2016-06-21 15:21:22 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:21:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:21:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:21:22 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:21:22 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:21:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:21:22 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:25 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:25 GainCapital FIX Trading socket (14) | Connected. | 2016-06-21 15:21:25 GainCapital FIX Trading socket (14) | Starting TLS 1.2 connection. | 2016-06-21 15:21:25 GainCapital FIX Trading socket (14) | SSL connection established. | 2016-06-21 15:21:39 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:21:39 GainCapital FIX Trading socket (14) | Closed. No error. | 2016-06-21 15:21:39 GainCapital FIX Trading socket (14) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:21:39 GainCapital FIX Trading socket (14) | SSL has been shut down. | 2016-06-21 15:21:39 GainCapital FIX Trading socket (14) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:21:39 GainCapital FIX Trading socket (14) | Shutdown and closed. | 2016-06-21 15:21:39 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:21:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:21:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:21:39 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:21:39 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:21:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:21:39 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:42 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:42 GainCapital FIX Trading socket (15) | Connected. | 2016-06-21 15:21:42 GainCapital FIX Trading socket (15) | Starting TLS 1.2 connection. | 2016-06-21 15:21:42 GainCapital FIX Trading socket (15) | SSL connection established. | 2016-06-21 15:21:46 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:21:47 GainCapital FIX Trading socket (15) | Closed. No error. | 2016-06-21 15:21:47 GainCapital FIX Trading socket (15) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:21:47 GainCapital FIX Trading socket (15) | SSL has been shut down. | 2016-06-21 15:21:47 GainCapital FIX Trading socket (15) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:21:47 GainCapital FIX Trading socket (15) | Shutdown and closed. | 2016-06-21 15:21:47 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:21:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:21:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:21:47 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:21:47 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:21:47 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:21:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:21:47 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:50 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:50 GainCapital FIX Trading socket (16) | Connected. | 2016-06-21 15:21:51 GainCapital FIX Trading socket (16) | Starting TLS 1.2 connection. | 2016-06-21 15:21:51 GainCapital FIX Trading socket (16) | SSL connection established. | 2016-06-21 15:21:51 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:21:52 GainCapital FIX Trading socket (16) | Closed. No error. | 2016-06-21 15:21:52 GainCapital FIX Trading socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:21:52 GainCapital FIX Trading socket (16) | SSL has been shut down. | 2016-06-21 15:21:52 GainCapital FIX Trading socket (16) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:21:52 GainCapital FIX Trading socket (16) | Shutdown and closed. | 2016-06-21 15:21:52 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:21:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:21:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:21:52 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:21:52 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:21:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:21:52 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:21:55 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:21:55 GainCapital FIX Trading socket (17) | Connected. | 2016-06-21 15:21:58 GainCapital FIX Trading socket (17) | Starting TLS 1.2 connection. | 2016-06-21 15:21:58 GainCapital FIX Trading socket (17) | SSL connection established. | 2016-06-21 15:22:00 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:00 GainCapital FIX Trading socket (17) | Closed. No error. | 2016-06-21 15:22:00 GainCapital FIX Trading socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:00 GainCapital FIX Trading socket (17) | SSL has been shut down. | 2016-06-21 15:22:00 GainCapital FIX Trading socket (17) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:00 GainCapital FIX Trading socket (17) | Shutdown and closed. | 2016-06-21 15:22:00 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:00 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:00 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:22:00 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:00 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:03 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:03 GainCapital FIX Trading socket (18) | Connected. | 2016-06-21 15:22:04 GainCapital FIX Trading socket (18) | Starting TLS 1.2 connection. | 2016-06-21 15:22:04 GainCapital FIX Trading socket (18) | SSL connection established. | 2016-06-21 15:22:04 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:04 GainCapital FIX Trading socket (18) | Closed. No error. | 2016-06-21 15:22:05 GainCapital FIX Trading socket (18) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:05 GainCapital FIX Trading socket (18) | SSL has been shut down. | 2016-06-21 15:22:05 GainCapital FIX Trading socket (18) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:05 GainCapital FIX Trading socket (18) | Shutdown and closed. | 2016-06-21 15:22:05 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:05 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:05 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:05 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:08 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:08 GainCapital FIX Trading socket (19) | Connected. | 2016-06-21 15:22:08 GainCapital FIX Trading socket (19) | Starting TLS 1.2 connection. | 2016-06-21 15:22:08 GainCapital FIX Trading socket (19) | SSL connection established. | 2016-06-21 15:22:09 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:09 GainCapital FIX Trading socket (19) | Closed. No error. | 2016-06-21 15:22:09 GainCapital FIX Trading socket (19) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:09 GainCapital FIX Trading socket (19) | SSL has been shut down. | 2016-06-21 15:22:09 GainCapital FIX Trading socket (19) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:09 GainCapital FIX Trading socket (19) | Shutdown and closed. | 2016-06-21 15:22:09 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:09 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:09 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:22:09 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:09 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:12 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:13 GainCapital FIX Trading socket (20) | Connected. | 2016-06-21 15:22:16 GainCapital FIX Trading socket (20) | Starting TLS 1.2 connection. | 2016-06-21 15:22:16 GainCapital FIX Trading socket (20) | SSL connection established. | 2016-06-21 15:22:20 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:20 GainCapital FIX Trading socket (20) | Closed. No error. | 2016-06-21 15:22:21 GainCapital FIX Trading socket (20) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:21 GainCapital FIX Trading socket (20) | SSL has been shut down. | 2016-06-21 15:22:21 GainCapital FIX Trading socket (20) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:21 GainCapital FIX Trading socket (20) | Shutdown and closed. | 2016-06-21 15:22:21 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:21 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:21 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:21 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:24 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:24 GainCapital FIX Trading socket (22) | Connected. | 2016-06-21 15:22:24 GainCapital FIX Trading socket (22) | Starting TLS 1.2 connection. | 2016-06-21 15:22:24 GainCapital FIX Trading socket (22) | SSL connection established. | 2016-06-21 15:22:31 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:31 GainCapital FIX Trading socket (22) | Closed. No error. | 2016-06-21 15:22:32 GainCapital FIX Trading socket (22) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:32 GainCapital FIX Trading socket (22) | SSL has been shut down. | 2016-06-21 15:22:32 GainCapital FIX Trading socket (22) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:32 GainCapital FIX Trading socket (22) | Shutdown and closed. | 2016-06-21 15:22:32 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:32 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:32 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:32 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:35 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:35 GainCapital FIX Trading socket (23) | Connected. | 2016-06-21 15:22:35 GainCapital FIX Trading socket (23) | Starting TLS 1.2 connection. | 2016-06-21 15:22:35 GainCapital FIX Trading socket (23) | SSL connection established. | 2016-06-21 15:22:35 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:36 GainCapital FIX Trading socket (23) | Closed. No error. | 2016-06-21 15:22:36 GainCapital FIX Trading socket (23) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:36 GainCapital FIX Trading socket (23) | SSL has been shut down. | 2016-06-21 15:22:36 GainCapital FIX Trading socket (23) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:36 GainCapital FIX Trading socket (23) | Shutdown and closed. | 2016-06-21 15:22:36 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:36 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:36 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:22:36 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:36 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:39 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:39 GainCapital FIX Trading socket (24) | Connected. | 2016-06-21 15:22:39 GainCapital FIX Trading socket (24) | Starting TLS 1.2 connection. | 2016-06-21 15:22:39 GainCapital FIX Trading socket (24) | SSL connection established. | 2016-06-21 15:22:40 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:40 GainCapital FIX Trading socket (24) | Closed. No error. | 2016-06-21 15:22:40 GainCapital FIX Trading socket (24) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:40 GainCapital FIX Trading socket (24) | SSL has been shut down. | 2016-06-21 15:22:40 GainCapital FIX Trading socket (24) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:40 GainCapital FIX Trading socket (24) | Shutdown and closed. | 2016-06-21 15:22:40 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:40 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:40 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:40 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:43 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:43 GainCapital FIX Trading socket (25) | Connected. | 2016-06-21 15:22:43 GainCapital FIX Trading socket (25) | Starting TLS 1.2 connection. | 2016-06-21 15:22:43 GainCapital FIX Trading socket (25) | SSL connection established. | 2016-06-21 15:22:44 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:44 GainCapital FIX Trading socket (25) | Closed. No error. | 2016-06-21 15:22:44 GainCapital FIX Trading socket (25) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:44 GainCapital FIX Trading socket (25) | SSL has been shut down. | 2016-06-21 15:22:44 GainCapital FIX Trading socket (25) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:44 GainCapital FIX Trading socket (25) | Shutdown and closed. | 2016-06-21 15:22:44 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:44 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:44 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:22:44 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:44 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:47 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:47 GainCapital FIX Trading socket (26) | Connected. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | Starting TLS 1.2 connection. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | SSL connection established. | 2016-06-21 15:22:48 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | Closed. No error. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | SSL has been shut down. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:48 GainCapital FIX Trading socket (26) | Shutdown and closed. | 2016-06-21 15:22:48 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:48 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:48 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:48 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:51 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:51 GainCapital FIX Trading socket (27) | Connected. | 2016-06-21 15:22:52 GainCapital FIX Trading socket (27) | Starting TLS 1.2 connection. | 2016-06-21 15:22:52 GainCapital FIX Trading socket (27) | SSL connection established. | 2016-06-21 15:22:52 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:52 GainCapital FIX Trading socket (27) | Closed. No error. | 2016-06-21 15:22:53 GainCapital FIX Trading socket (27) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:53 GainCapital FIX Trading socket (27) | SSL has been shut down. | 2016-06-21 15:22:53 GainCapital FIX Trading socket (27) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:53 GainCapital FIX Trading socket (27) | Shutdown and closed. | 2016-06-21 15:22:53 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:53 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:53 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:22:53 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:53 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:22:56 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:22:56 GainCapital FIX Trading socket (28) | Connected. | 2016-06-21 15:22:56 GainCapital FIX Trading socket (28) | Starting TLS 1.2 connection. | 2016-06-21 15:22:56 GainCapital FIX Trading socket (28) | SSL connection established. | 2016-06-21 15:22:56 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:22:56 GainCapital FIX Trading socket (28) | Closed. No error. | 2016-06-21 15:22:57 GainCapital FIX Trading socket (28) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:22:57 GainCapital FIX Trading socket (28) | SSL has been shut down. | 2016-06-21 15:22:57 GainCapital FIX Trading socket (28) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:22:57 GainCapital FIX Trading socket (28) | Shutdown and closed. | 2016-06-21 15:22:57 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:22:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:22:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:22:57 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:22:57 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:22:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:22:57 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:00 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:00 GainCapital FIX Trading socket (29) | Connected. | 2016-06-21 15:23:00 GainCapital FIX Trading socket (29) | Starting TLS 1.2 connection. | 2016-06-21 15:23:00 GainCapital FIX Trading socket (29) | SSL connection established. | 2016-06-21 15:23:00 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:01 GainCapital FIX Trading socket (29) | Closed. No error. | 2016-06-21 15:23:01 GainCapital FIX Trading socket (29) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:01 GainCapital FIX Trading socket (29) | SSL has been shut down. | 2016-06-21 15:23:01 GainCapital FIX Trading socket (29) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:01 GainCapital FIX Trading socket (29) | Shutdown and closed. | 2016-06-21 15:23:01 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:01 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:01 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:01 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:01 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:04 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:04 GainCapital FIX Trading socket (30) | Connected. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | Starting TLS 1.2 connection. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | SSL connection established. | 2016-06-21 15:23:05 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | Closed. No error. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | SSL has been shut down. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:05 GainCapital FIX Trading socket (30) | Shutdown and closed. | 2016-06-21 15:23:05 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:05 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:05 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:05 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:08 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:08 GainCapital FIX Trading socket (31) | Connected. | 2016-06-21 15:23:09 GainCapital FIX Trading socket (31) | Starting TLS 1.2 connection. | 2016-06-21 15:23:09 GainCapital FIX Trading socket (31) | SSL connection established. | 2016-06-21 15:23:09 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:09 GainCapital FIX Trading socket (31) | Closed. No error. | 2016-06-21 15:23:10 GainCapital FIX Trading socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:10 GainCapital FIX Trading socket (31) | SSL has been shut down. | 2016-06-21 15:23:10 GainCapital FIX Trading socket (31) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:10 GainCapital FIX Trading socket (31) | Shutdown and closed. | 2016-06-21 15:23:10 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:10 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:10 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:10 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:10 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:13 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:13 GainCapital FIX Trading socket (32) | Connected. | 2016-06-21 15:23:13 GainCapital FIX Trading socket (32) | Starting TLS 1.2 connection. | 2016-06-21 15:23:13 GainCapital FIX Trading socket (32) | SSL connection established. | 2016-06-21 15:23:13 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:13 GainCapital FIX Trading socket (32) | Closed. No error. | 2016-06-21 15:23:14 GainCapital FIX Trading socket (32) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:14 GainCapital FIX Trading socket (32) | SSL has been shut down. | 2016-06-21 15:23:14 GainCapital FIX Trading socket (32) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:14 GainCapital FIX Trading socket (32) | Shutdown and closed. | 2016-06-21 15:23:14 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:14 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:14 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:14 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:17 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:17 GainCapital FIX Trading socket (33) | Connected. | 2016-06-21 15:23:17 GainCapital FIX Trading socket (33) | Starting TLS 1.2 connection. | 2016-06-21 15:23:17 GainCapital FIX Trading socket (33) | SSL connection established. | 2016-06-21 15:23:17 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:18 GainCapital FIX Trading socket (33) | Closed. No error. | 2016-06-21 15:23:18 GainCapital FIX Trading socket (33) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:18 GainCapital FIX Trading socket (33) | SSL has been shut down. | 2016-06-21 15:23:18 GainCapital FIX Trading socket (33) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:18 GainCapital FIX Trading socket (33) | Shutdown and closed. | 2016-06-21 15:23:18 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:18 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:18 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:18 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:18 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:21 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:21 GainCapital FIX Trading socket (34) | Connected. | 2016-06-21 15:23:21 GainCapital FIX Trading socket (34) | Starting TLS 1.2 connection. | 2016-06-21 15:23:21 GainCapital FIX Trading socket (34) | SSL connection established. | 2016-06-21 15:23:21 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:22 GainCapital FIX Trading socket (34) | Closed. No error. | 2016-06-21 15:23:22 GainCapital FIX Trading socket (34) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:22 GainCapital FIX Trading socket (34) | SSL has been shut down. | 2016-06-21 15:23:22 GainCapital FIX Trading socket (34) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:22 GainCapital FIX Trading socket (34) | Shutdown and closed. | 2016-06-21 15:23:22 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:22 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:22 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:22 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:25 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:25 GainCapital FIX Trading socket (35) | Connected. | 2016-06-21 15:23:25 GainCapital FIX Trading socket (35) | Starting TLS 1.2 connection. | 2016-06-21 15:23:25 GainCapital FIX Trading socket (35) | SSL connection established. | 2016-06-21 15:23:26 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:26 GainCapital FIX Trading socket (35) | Closed. No error. | 2016-06-21 15:23:26 GainCapital FIX Trading socket (35) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:26 GainCapital FIX Trading socket (35) | SSL has been shut down. | 2016-06-21 15:23:26 GainCapital FIX Trading socket (35) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:26 GainCapital FIX Trading socket (35) | Shutdown and closed. | 2016-06-21 15:23:26 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:26 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:26 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:26 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:26 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:29 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:29 GainCapital FIX Trading socket (36) | Connected. | 2016-06-21 15:23:29 GainCapital FIX Trading socket (36) | Starting TLS 1.2 connection. | 2016-06-21 15:23:29 GainCapital FIX Trading socket (36) | SSL connection established. | 2016-06-21 15:23:30 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:30 GainCapital FIX Trading socket (36) | Closed. No error. | 2016-06-21 15:23:30 GainCapital FIX Trading socket (36) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:30 GainCapital FIX Trading socket (36) | SSL has been shut down. | 2016-06-21 15:23:30 GainCapital FIX Trading socket (36) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:30 GainCapital FIX Trading socket (36) | Shutdown and closed. | 2016-06-21 15:23:30 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:30 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:30 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:30 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:33 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:33 GainCapital FIX Trading socket (37) | Connected. | 2016-06-21 15:23:33 GainCapital FIX Trading socket (37) | Starting TLS 1.2 connection. | 2016-06-21 15:23:33 GainCapital FIX Trading socket (37) | SSL connection established. | 2016-06-21 15:23:34 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:34 GainCapital FIX Trading socket (37) | Closed. No error. | 2016-06-21 15:23:35 GainCapital FIX Trading socket (37) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:35 GainCapital FIX Trading socket (37) | SSL has been shut down. | 2016-06-21 15:23:35 GainCapital FIX Trading socket (37) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:35 GainCapital FIX Trading socket (37) | Shutdown and closed. | 2016-06-21 15:23:35 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:35 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:35 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:35 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:35 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:38 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:38 GainCapital FIX Trading socket (38) | Connected. | 2016-06-21 15:23:38 GainCapital FIX Trading socket (38) | Starting TLS 1.2 connection. | 2016-06-21 15:23:38 GainCapital FIX Trading socket (38) | SSL connection established. | 2016-06-21 15:23:38 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:38 GainCapital FIX Trading socket (38) | Closed. No error. | 2016-06-21 15:23:39 GainCapital FIX Trading socket (38) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:39 GainCapital FIX Trading socket (38) | SSL has been shut down. | 2016-06-21 15:23:39 GainCapital FIX Trading socket (38) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:39 GainCapital FIX Trading socket (38) | Shutdown and closed. | 2016-06-21 15:23:39 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:39 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:39 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:39 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:42 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:42 GainCapital FIX Trading socket (39) | Connected. | 2016-06-21 15:23:42 GainCapital FIX Trading socket (39) | Starting TLS 1.2 connection. | 2016-06-21 15:23:42 GainCapital FIX Trading socket (39) | SSL connection established. | 2016-06-21 15:23:42 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:43 GainCapital FIX Trading socket (39) | Closed. No error. | 2016-06-21 15:23:43 GainCapital FIX Trading socket (39) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:43 GainCapital FIX Trading socket (39) | SSL has been shut down. | 2016-06-21 15:23:43 GainCapital FIX Trading socket (39) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:43 GainCapital FIX Trading socket (39) | Shutdown and closed. | 2016-06-21 15:23:43 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:43 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:43 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:43 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:43 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:46 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:46 GainCapital FIX Trading socket (40) | Connected. | 2016-06-21 15:23:46 GainCapital FIX Trading socket (40) | Starting TLS 1.2 connection. | 2016-06-21 15:23:46 GainCapital FIX Trading socket (40) | SSL connection established. | 2016-06-21 15:23:46 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:47 GainCapital FIX Trading socket (40) | Closed. No error. | 2016-06-21 15:23:47 GainCapital FIX Trading socket (40) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:47 GainCapital FIX Trading socket (40) | SSL has been shut down. | 2016-06-21 15:23:47 GainCapital FIX Trading socket (40) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:47 GainCapital FIX Trading socket (40) | Shutdown and closed. | 2016-06-21 15:23:47 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:47 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:47 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:47 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:50 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:50 GainCapital FIX Trading socket (41) | Connected. | 2016-06-21 15:23:50 GainCapital FIX Trading socket (41) | Starting TLS 1.2 connection. | 2016-06-21 15:23:50 GainCapital FIX Trading socket (41) | SSL connection established. | 2016-06-21 15:23:54 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:23:54 GainCapital FIX Trading socket (41) | Closed. No error. | 2016-06-21 15:23:54 GainCapital FIX Trading socket (41) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:23:54 GainCapital FIX Trading socket (41) | SSL has been shut down. | 2016-06-21 15:23:54 GainCapital FIX Trading socket (41) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:23:54 GainCapital FIX Trading socket (41) | Shutdown and closed. | 2016-06-21 15:23:54 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:23:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:23:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:23:54 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:23:54 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:23:54 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:23:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:23:54 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:23:57 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:23:57 GainCapital FIX Trading socket (42) | Connected. | 2016-06-21 15:23:58 GainCapital FIX Trading socket (42) | Starting TLS 1.2 connection. | 2016-06-21 15:23:58 GainCapital FIX Trading socket (42) | SSL connection established. | 2016-06-21 15:24:01 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:24:01 GainCapital FIX Trading: Sent heartbeat to server. | 2016-06-21 15:24:31 Service connection timed out. Will disconnect and retry. | 2016-06-21 15:24:57 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:24:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:24:57 GainCapital FIX Trading: DisconnectFIX called. | 2016-06-21 15:24:57 GainCapital FIX Trading: Sending a Logout message. | 2016-06-21 15:24:57 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:24:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:24:57 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:00 GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-06-21 15:25:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:00 GainCapital FIX Trading: DisconnectFIX called. | 2016-06-21 15:25:00 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:00 GainCapital FIX Trading socket (42) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2016-06-21 15:25:01 GainCapital FIX Trading socket (42) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:01 GainCapital FIX Trading socket (42) | SSL has been shut down. | 2016-06-21 15:25:01 GainCapital FIX Trading socket (42) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:01 GainCapital FIX Trading socket (42) | Shutdown and closed. | 2016-06-21 15:25:01 GainCapital FIX Trading: Socket closed without completing the logout sequence. | 2016-06-21 15:25:01 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:01 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:03 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:03 GainCapital FIX Trading socket (44) | Connected. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | Starting TLS 1.2 connection. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | SSL connection established. | 2016-06-21 15:25:04 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | Closed. No error. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | SSL has been shut down. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:04 GainCapital FIX Trading socket (44) | Shutdown and closed. | 2016-06-21 15:25:04 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:04 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:04 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:25:04 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:05 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:07 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:07 GainCapital FIX Trading socket (45) | Connected. | 2016-06-21 15:25:08 GainCapital FIX Trading socket (45) | Starting TLS 1.2 connection. | 2016-06-21 15:25:08 GainCapital FIX Trading socket (45) | SSL connection established. | 2016-06-21 15:25:08 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:08 GainCapital FIX Trading socket (45) | Closed. No error. | 2016-06-21 15:25:09 GainCapital FIX Trading socket (45) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:09 GainCapital FIX Trading socket (45) | SSL has been shut down. | 2016-06-21 15:25:09 GainCapital FIX Trading socket (45) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:09 GainCapital FIX Trading socket (45) | Shutdown and closed. | 2016-06-21 15:25:09 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:09 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:09 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:09 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:12 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:12 GainCapital FIX Trading socket (46) | Connected. | 2016-06-21 15:25:12 GainCapital FIX Trading socket (46) | Starting TLS 1.2 connection. | 2016-06-21 15:25:12 GainCapital FIX Trading socket (46) | SSL connection established. | 2016-06-21 15:25:12 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:12 GainCapital FIX Trading socket (46) | Closed. No error. | 2016-06-21 15:25:13 GainCapital FIX Trading socket (46) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:13 GainCapital FIX Trading socket (46) | SSL has been shut down. | 2016-06-21 15:25:13 GainCapital FIX Trading socket (46) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:13 GainCapital FIX Trading socket (46) | Shutdown and closed. | 2016-06-21 15:25:13 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:13 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:13 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:25:13 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:13 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:13 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:16 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:16 GainCapital FIX Trading socket (47) | Connected. | 2016-06-21 15:25:16 GainCapital FIX Trading socket (47) | Starting TLS 1.2 connection. | 2016-06-21 15:25:16 GainCapital FIX Trading socket (47) | SSL connection established. | 2016-06-21 15:25:16 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:16 GainCapital FIX Trading socket (47) | Closed. No error. | 2016-06-21 15:25:17 GainCapital FIX Trading socket (47) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:17 GainCapital FIX Trading socket (47) | SSL has been shut down. | 2016-06-21 15:25:17 GainCapital FIX Trading socket (47) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:17 GainCapital FIX Trading socket (47) | Shutdown and closed. | 2016-06-21 15:25:17 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:17 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:17 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:17 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:20 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:20 GainCapital FIX Trading socket (48) | Connected. | 2016-06-21 15:25:20 GainCapital FIX Trading socket (48) | Starting TLS 1.2 connection. | 2016-06-21 15:25:20 GainCapital FIX Trading socket (48) | SSL connection established. | 2016-06-21 15:25:21 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:21 GainCapital FIX Trading socket (48) | Closed. No error. | 2016-06-21 15:25:21 GainCapital FIX Trading socket (48) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:21 GainCapital FIX Trading socket (48) | SSL has been shut down. | 2016-06-21 15:25:21 GainCapital FIX Trading socket (48) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:21 GainCapital FIX Trading socket (48) | Shutdown and closed. | 2016-06-21 15:25:21 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:21 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:21 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:25:21 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:21 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:21 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:24 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:24 GainCapital FIX Trading socket (49) | Connected. | 2016-06-21 15:25:24 GainCapital FIX Trading socket (49) | Starting TLS 1.2 connection. | 2016-06-21 15:25:24 GainCapital FIX Trading socket (49) | SSL connection established. | 2016-06-21 15:25:25 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:25 GainCapital FIX Trading socket (49) | Closed. No error. | 2016-06-21 15:25:25 GainCapital FIX Trading socket (49) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:25 GainCapital FIX Trading socket (49) | SSL has been shut down. | 2016-06-21 15:25:25 GainCapital FIX Trading socket (49) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:25 GainCapital FIX Trading socket (49) | Shutdown and closed. | 2016-06-21 15:25:25 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:25 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:25 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:25 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:28 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:28 GainCapital FIX Trading socket (50) | Connected. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | Starting TLS 1.2 connection. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | SSL connection established. | 2016-06-21 15:25:29 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | Closed. No error. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | SSL has been shut down. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:29 GainCapital FIX Trading socket (50) | Shutdown and closed. | 2016-06-21 15:25:29 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:29 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:29 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:25:29 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:29 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:32 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:32 GainCapital FIX Trading socket (51) | Connected. | 2016-06-21 15:25:33 GainCapital FIX Trading socket (51) | Starting TLS 1.2 connection. | 2016-06-21 15:25:33 GainCapital FIX Trading socket (51) | SSL connection established. | 2016-06-21 15:25:33 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:33 GainCapital FIX Trading socket (51) | Closed. No error. | 2016-06-21 15:25:34 GainCapital FIX Trading socket (51) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:34 GainCapital FIX Trading socket (51) | SSL has been shut down. | 2016-06-21 15:25:34 GainCapital FIX Trading socket (51) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:34 GainCapital FIX Trading socket (51) | Shutdown and closed. | 2016-06-21 15:25:34 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:34 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:34 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:34 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:37 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:37 GainCapital FIX Trading socket (52) | Connected. | 2016-06-21 15:25:37 GainCapital FIX Trading socket (52) | Starting TLS 1.2 connection. | 2016-06-21 15:25:37 GainCapital FIX Trading socket (52) | SSL connection established. | 2016-06-21 15:25:37 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:37 GainCapital FIX Trading socket (52) | Closed. No error. | 2016-06-21 15:25:38 GainCapital FIX Trading socket (52) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:38 GainCapital FIX Trading socket (52) | SSL has been shut down. | 2016-06-21 15:25:38 GainCapital FIX Trading socket (52) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:38 GainCapital FIX Trading socket (52) | Shutdown and closed. | 2016-06-21 15:25:38 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:38 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:38 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:25:38 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:38 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:38 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:41 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:41 GainCapital FIX Trading socket (53) | Connected. | 2016-06-21 15:25:41 GainCapital FIX Trading socket (53) | Starting TLS 1.2 connection. | 2016-06-21 15:25:41 GainCapital FIX Trading socket (53) | SSL connection established. | 2016-06-21 15:25:41 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:41 GainCapital FIX Trading socket (53) | Closed. No error. | 2016-06-21 15:25:42 GainCapital FIX Trading socket (53) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:42 GainCapital FIX Trading socket (53) | SSL has been shut down. | 2016-06-21 15:25:42 GainCapital FIX Trading socket (53) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:42 GainCapital FIX Trading socket (53) | Shutdown and closed. | 2016-06-21 15:25:42 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:42 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:42 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:42 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:25:45 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:25:45 GainCapital FIX Trading socket (54) | Connected. | 2016-06-21 15:25:45 GainCapital FIX Trading socket (54) | Starting TLS 1.2 connection. | 2016-06-21 15:25:45 GainCapital FIX Trading socket (54) | SSL connection established. | 2016-06-21 15:25:45 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:25:46 GainCapital FIX Trading socket (54) | Closed. No error. | 2016-06-21 15:25:46 GainCapital FIX Trading socket (54) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:25:46 GainCapital FIX Trading socket (54) | SSL has been shut down. | 2016-06-21 15:25:46 GainCapital FIX Trading socket (54) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:25:46 GainCapital FIX Trading socket (54) | Shutdown and closed. | 2016-06-21 15:25:46 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:25:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:25:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:25:46 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:25:46 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:25:46 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:25:46 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:25:46 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:27:46 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:27:46 GainCapital FIX Trading socket (56) | Connected. | 2016-06-21 15:27:46 GainCapital FIX Trading socket (56) | Starting TLS 1.2 connection. | 2016-06-21 15:27:46 GainCapital FIX Trading socket (56) | SSL connection established. | 2016-06-21 15:27:47 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:27:47 GainCapital FIX Trading socket (56) | Closed. No error. | 2016-06-21 15:27:47 GainCapital FIX Trading socket (56) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:27:47 GainCapital FIX Trading socket (56) | SSL has been shut down. | 2016-06-21 15:27:47 GainCapital FIX Trading socket (56) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:27:47 GainCapital FIX Trading socket (56) | Shutdown and closed. | 2016-06-21 15:27:47 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:27:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:27:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:27:47 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:27:47 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:27:47 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:27:47 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:29:47 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:29:47 GainCapital FIX Trading socket (58) | Connected. | 2016-06-21 15:29:47 GainCapital FIX Trading socket (58) | Starting TLS 1.2 connection. | 2016-06-21 15:29:47 GainCapital FIX Trading socket (58) | SSL connection established. | 2016-06-21 15:29:48 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:29:48 GainCapital FIX Trading socket (58) | Closed. No error. | 2016-06-21 15:29:48 GainCapital FIX Trading socket (58) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:29:48 GainCapital FIX Trading socket (58) | SSL has been shut down. | 2016-06-21 15:29:48 GainCapital FIX Trading socket (58) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:29:48 GainCapital FIX Trading socket (58) | Shutdown and closed. | 2016-06-21 15:29:48 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:29:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:29:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:29:48 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:29:48 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:29:48 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:29:48 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:29:48 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:31:48 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:31:48 GainCapital FIX Trading socket (60) | Connected. | 2016-06-21 15:31:48 GainCapital FIX Trading socket (60) | Starting TLS 1.2 connection. | 2016-06-21 15:31:48 GainCapital FIX Trading socket (60) | SSL connection established. | 2016-06-21 15:31:49 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:31:49 GainCapital FIX Trading socket (60) | Closed. No error. | 2016-06-21 15:31:49 GainCapital FIX Trading socket (60) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:31:49 GainCapital FIX Trading socket (60) | SSL has been shut down. | 2016-06-21 15:31:49 GainCapital FIX Trading socket (60) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:31:49 GainCapital FIX Trading socket (60) | Shutdown and closed. | 2016-06-21 15:31:49 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:31:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:31:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:31:49 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:31:49 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:31:49 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:31:49 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:33:49 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:33:49 GainCapital FIX Trading socket (62) | Connected. | 2016-06-21 15:33:50 GainCapital FIX Trading socket (62) | Starting TLS 1.2 connection. | 2016-06-21 15:33:50 GainCapital FIX Trading socket (62) | SSL connection established. | 2016-06-21 15:33:50 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:33:50 GainCapital FIX Trading socket (62) | Closed. No error. | 2016-06-21 15:33:51 GainCapital FIX Trading socket (62) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:33:51 GainCapital FIX Trading socket (62) | SSL has been shut down. | 2016-06-21 15:33:51 GainCapital FIX Trading socket (62) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:33:51 GainCapital FIX Trading socket (62) | Shutdown and closed. | 2016-06-21 15:33:51 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:33:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:33:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:33:51 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:33:51 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:33:51 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:33:51 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:33:51 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:35:50 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:35:50 GainCapital FIX Trading socket (64) | Connected. | 2016-06-21 15:35:51 GainCapital FIX Trading socket (64) | Starting TLS 1.2 connection. | 2016-06-21 15:35:51 GainCapital FIX Trading socket (64) | SSL connection established. | 2016-06-21 15:35:51 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:35:51 GainCapital FIX Trading socket (64) | Closed. No error. | 2016-06-21 15:35:52 GainCapital FIX Trading socket (64) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:35:52 GainCapital FIX Trading socket (64) | SSL has been shut down. | 2016-06-21 15:35:52 GainCapital FIX Trading socket (64) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:35:52 GainCapital FIX Trading socket (64) | Shutdown and closed. | 2016-06-21 15:35:52 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:35:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:35:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:35:52 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:35:52 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:35:52 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:35:52 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:37:52 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:37:52 GainCapital FIX Trading socket (66) | Connected. | 2016-06-21 15:37:52 GainCapital FIX Trading socket (66) | Starting TLS 1.2 connection. | 2016-06-21 15:37:52 GainCapital FIX Trading socket (66) | SSL connection established. | 2016-06-21 15:37:53 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:37:53 GainCapital FIX Trading socket (66) | Closed. No error. | 2016-06-21 15:37:53 GainCapital FIX Trading socket (66) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:37:53 GainCapital FIX Trading socket (66) | SSL has been shut down. | 2016-06-21 15:37:53 GainCapital FIX Trading socket (66) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:37:53 GainCapital FIX Trading socket (66) | Shutdown and closed. | 2016-06-21 15:37:53 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:37:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:37:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:37:53 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:37:53 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:37:53 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:37:53 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:37:53 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:39:53 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:39:53 GainCapital FIX Trading socket (68) | Connected. | 2016-06-21 15:39:53 GainCapital FIX Trading socket (68) | Starting TLS 1.2 connection. | 2016-06-21 15:39:53 GainCapital FIX Trading socket (68) | SSL connection established. | 2016-06-21 15:39:54 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:39:54 GainCapital FIX Trading socket (68) | Closed. No error. | 2016-06-21 15:39:54 GainCapital FIX Trading socket (68) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:39:54 GainCapital FIX Trading socket (68) | SSL has been shut down. | 2016-06-21 15:39:54 GainCapital FIX Trading socket (68) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:39:54 GainCapital FIX Trading socket (68) | Shutdown and closed. | 2016-06-21 15:39:54 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:39:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:39:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:39:54 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:39:54 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:39:54 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:39:54 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:41:54 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:41:54 GainCapital FIX Trading socket (70) | Connected. | 2016-06-21 15:41:54 GainCapital FIX Trading socket (70) | Starting TLS 1.2 connection. | 2016-06-21 15:41:54 GainCapital FIX Trading socket (70) | SSL connection established. | 2016-06-21 15:41:55 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:41:55 GainCapital FIX Trading socket (70) | Closed. No error. | 2016-06-21 15:41:55 GainCapital FIX Trading socket (70) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:41:55 GainCapital FIX Trading socket (70) | SSL has been shut down. | 2016-06-21 15:41:55 GainCapital FIX Trading socket (70) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:41:55 GainCapital FIX Trading socket (70) | Shutdown and closed. | 2016-06-21 15:41:55 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:41:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:41:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:41:55 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:41:55 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:41:55 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:41:55 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:41:55 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:43:55 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:43:55 GainCapital FIX Trading socket (72) | Connected. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | Starting TLS 1.2 connection. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | SSL connection established. | 2016-06-21 15:43:56 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | Closed. No error. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | SSL has been shut down. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:43:56 GainCapital FIX Trading socket (72) | Shutdown and closed. | 2016-06-21 15:43:56 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:43:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:43:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:43:56 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:43:56 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:43:56 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:43:56 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:45:56 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:45:56 GainCapital FIX Trading socket (74) | Connected. | 2016-06-21 15:45:56 GainCapital FIX Trading socket (74) | Starting TLS 1.2 connection. | 2016-06-21 15:45:56 GainCapital FIX Trading socket (74) | SSL connection established. | 2016-06-21 15:45:57 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:45:57 GainCapital FIX Trading socket (74) | Closed. No error. | 2016-06-21 15:45:57 GainCapital FIX Trading socket (74) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:45:57 GainCapital FIX Trading socket (74) | SSL has been shut down. | 2016-06-21 15:45:57 GainCapital FIX Trading socket (74) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:45:57 GainCapital FIX Trading socket (74) | Shutdown and closed. | 2016-06-21 15:45:57 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:45:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:45:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:45:57 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:45:57 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:45:57 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:45:57 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:45:57 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:47:58 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:47:58 GainCapital FIX Trading socket (76) | Connected. | 2016-06-21 15:48:01 GainCapital FIX Trading socket (76) | Starting TLS 1.2 connection. | 2016-06-21 15:48:01 GainCapital FIX Trading socket (76) | SSL connection established. | 2016-06-21 15:48:01 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:48:02 GainCapital FIX Trading socket (76) | Closed. No error. | 2016-06-21 15:48:02 GainCapital FIX Trading socket (76) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:48:02 GainCapital FIX Trading socket (76) | SSL has been shut down. | 2016-06-21 15:48:02 GainCapital FIX Trading socket (76) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:48:02 GainCapital FIX Trading socket (76) | Shutdown and closed. | 2016-06-21 15:48:02 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:48:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:48:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:48:02 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:48:02 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:48:02 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:48:02 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:50:02 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:50:02 GainCapital FIX Trading socket (78) | Connected. | 2016-06-21 15:50:02 GainCapital FIX Trading socket (78) | Starting TLS 1.2 connection. | 2016-06-21 15:50:02 GainCapital FIX Trading socket (78) | SSL connection established. | 2016-06-21 15:50:02 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:50:03 GainCapital FIX Trading socket (78) | Closed. No error. | 2016-06-21 15:50:03 GainCapital FIX Trading socket (78) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:50:03 GainCapital FIX Trading socket (78) | SSL has been shut down. | 2016-06-21 15:50:03 GainCapital FIX Trading socket (78) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:50:03 GainCapital FIX Trading socket (78) | Shutdown and closed. | 2016-06-21 15:50:03 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:50:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:50:03 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:50:03 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:50:03 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:50:03 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:50:03 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:50:03 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:52:03 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:52:03 GainCapital FIX Trading socket (80) | Connected. | 2016-06-21 15:52:03 GainCapital FIX Trading socket (80) | Starting TLS 1.2 connection. | 2016-06-21 15:52:03 GainCapital FIX Trading socket (80) | SSL connection established. | 2016-06-21 15:52:04 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:52:04 GainCapital FIX Trading socket (80) | Closed. No error. | 2016-06-21 15:52:04 GainCapital FIX Trading socket (80) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:52:04 GainCapital FIX Trading socket (80) | SSL has been shut down. | 2016-06-21 15:52:04 GainCapital FIX Trading socket (80) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:52:04 GainCapital FIX Trading socket (80) | Shutdown and closed. | 2016-06-21 15:52:04 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:52:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:52:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:52:04 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:52:04 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:52:04 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:52:04 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:54:04 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:54:04 GainCapital FIX Trading socket (82) | Connected. | 2016-06-21 15:54:04 GainCapital FIX Trading socket (82) | Starting TLS 1.2 connection. | 2016-06-21 15:54:04 GainCapital FIX Trading socket (82) | SSL connection established. | 2016-06-21 15:54:05 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:54:05 GainCapital FIX Trading socket (82) | Closed. No error. | 2016-06-21 15:54:05 GainCapital FIX Trading socket (82) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:54:05 GainCapital FIX Trading socket (82) | SSL has been shut down. | 2016-06-21 15:54:05 GainCapital FIX Trading socket (82) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:54:05 GainCapital FIX Trading socket (82) | Shutdown and closed. | 2016-06-21 15:54:05 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:54:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:54:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:54:05 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:54:05 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:54:05 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:54:05 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:54:05 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:56:05 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:56:05 GainCapital FIX Trading socket (84) | Connected. | 2016-06-21 15:56:05 GainCapital FIX Trading socket (84) | Starting TLS 1.2 connection. | 2016-06-21 15:56:05 GainCapital FIX Trading socket (84) | SSL connection established. | 2016-06-21 15:56:06 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:56:06 GainCapital FIX Trading socket (84) | Closed. No error. | 2016-06-21 15:56:06 GainCapital FIX Trading socket (84) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:56:06 GainCapital FIX Trading socket (84) | SSL has been shut down. | 2016-06-21 15:56:06 GainCapital FIX Trading socket (84) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:56:06 GainCapital FIX Trading socket (84) | Shutdown and closed. | 2016-06-21 15:56:06 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:56:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:56:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:56:06 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:56:06 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:56:06 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:56:06 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 15:58:06 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 15:58:06 GainCapital FIX Trading socket (86) | Connected. | 2016-06-21 15:58:07 GainCapital FIX Trading socket (86) | Starting TLS 1.2 connection. | 2016-06-21 15:58:07 GainCapital FIX Trading socket (86) | SSL connection established. | 2016-06-21 15:58:07 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 15:58:07 GainCapital FIX Trading socket (86) | Closed. No error. | 2016-06-21 15:58:08 GainCapital FIX Trading socket (86) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 15:58:08 GainCapital FIX Trading socket (86) | SSL has been shut down. | 2016-06-21 15:58:08 GainCapital FIX Trading socket (86) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 15:58:08 GainCapital FIX Trading socket (86) | Shutdown and closed. | 2016-06-21 15:58:08 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 15:58:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 15:58:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 15:58:08 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 15:58:08 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 15:58:08 GAIN Capital/OEC | Disconnected. | 2016-06-21 15:58:08 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 15:58:08 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:00:07 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:00:07 GainCapital FIX Trading socket (88) | Connected. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | Starting TLS 1.2 connection. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | SSL connection established. | 2016-06-21 16:00:08 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | Closed. No error. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | SSL has been shut down. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:00:08 GainCapital FIX Trading socket (88) | Shutdown and closed. | 2016-06-21 16:00:08 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:00:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:00:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:00:08 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:00:08 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:00:08 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:00:08 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:02:09 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:02:09 GainCapital FIX Trading socket (90) | Connected. | 2016-06-21 16:02:09 GainCapital FIX Trading socket (90) | Starting TLS 1.2 connection. | 2016-06-21 16:02:09 GainCapital FIX Trading socket (90) | SSL connection established. | 2016-06-21 16:02:10 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:02:10 GainCapital FIX Trading socket (90) | Closed. No error. | 2016-06-21 16:02:10 GainCapital FIX Trading socket (90) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:02:10 GainCapital FIX Trading socket (90) | SSL has been shut down. | 2016-06-21 16:02:10 GainCapital FIX Trading socket (90) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:02:10 GainCapital FIX Trading socket (90) | Shutdown and closed. | 2016-06-21 16:02:10 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:02:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:02:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:02:10 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:02:10 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 16:02:10 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:02:10 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:02:10 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:04:10 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:04:10 GainCapital FIX Trading socket (92) | Connected. | 2016-06-21 16:04:10 GainCapital FIX Trading socket (92) | Starting TLS 1.2 connection. | 2016-06-21 16:04:10 GainCapital FIX Trading socket (92) | SSL connection established. | 2016-06-21 16:04:10 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:04:11 GainCapital FIX Trading socket (92) | Closed. No error. | 2016-06-21 16:04:11 GainCapital FIX Trading socket (92) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:04:11 GainCapital FIX Trading socket (92) | SSL has been shut down. | 2016-06-21 16:04:11 GainCapital FIX Trading socket (92) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:04:11 GainCapital FIX Trading socket (92) | Shutdown and closed. | 2016-06-21 16:04:11 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:04:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:04:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:04:11 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:04:11 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:04:11 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:04:11 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:06:11 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:06:11 GainCapital FIX Trading socket (94) | Connected. | 2016-06-21 16:06:11 GainCapital FIX Trading socket (94) | Starting TLS 1.2 connection. | 2016-06-21 16:06:11 GainCapital FIX Trading socket (94) | SSL connection established. | 2016-06-21 16:06:11 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:06:12 GainCapital FIX Trading socket (94) | Closed. No error. | 2016-06-21 16:06:12 GainCapital FIX Trading socket (94) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:06:12 GainCapital FIX Trading socket (94) | SSL has been shut down. | 2016-06-21 16:06:12 GainCapital FIX Trading socket (94) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:06:12 GainCapital FIX Trading socket (94) | Shutdown and closed. | 2016-06-21 16:06:12 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:06:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:06:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:06:12 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:06:12 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 16:06:12 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:06:12 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:06:12 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:08:12 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:08:12 GainCapital FIX Trading socket (96) | Connected. | 2016-06-21 16:08:13 GainCapital FIX Trading socket (96) | Starting TLS 1.2 connection. | 2016-06-21 16:08:13 GainCapital FIX Trading socket (96) | SSL connection established. | 2016-06-21 16:08:17 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:08:17 GainCapital FIX Trading socket (96) | Closed. No error. | 2016-06-21 16:08:17 GainCapital FIX Trading socket (96) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:08:17 GainCapital FIX Trading socket (96) | SSL has been shut down. | 2016-06-21 16:08:17 GainCapital FIX Trading socket (96) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:08:17 GainCapital FIX Trading socket (96) | Shutdown and closed. | 2016-06-21 16:08:17 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:08:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:08:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:08:17 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:08:17 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:08:17 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:08:17 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:10:17 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:10:17 GainCapital FIX Trading socket (98) | Connected. | 2016-06-21 16:10:17 GainCapital FIX Trading socket (98) | Starting TLS 1.2 connection. | 2016-06-21 16:10:17 GainCapital FIX Trading socket (98) | SSL connection established. | 2016-06-21 16:10:18 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:10:18 GainCapital FIX Trading socket (98) | Closed. No error. | 2016-06-21 16:10:18 GainCapital FIX Trading socket (98) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:10:18 GainCapital FIX Trading socket (98) | SSL has been shut down. | 2016-06-21 16:10:18 GainCapital FIX Trading socket (98) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:10:18 GainCapital FIX Trading socket (98) | Shutdown and closed. | 2016-06-21 16:10:18 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:10:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:10:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:10:18 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:10:18 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 16:10:18 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:10:18 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:10:18 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:12:18 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:12:18 GainCapital FIX Trading socket (100) | Connected. | 2016-06-21 16:12:19 GainCapital FIX Trading socket (100) | Starting TLS 1.2 connection. | 2016-06-21 16:12:19 GainCapital FIX Trading socket (100) | SSL connection established. | 2016-06-21 16:12:19 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:12:19 GainCapital FIX Trading socket (100) | Closed. No error. | 2016-06-21 16:12:20 GainCapital FIX Trading socket (100) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:12:20 GainCapital FIX Trading socket (100) | SSL has been shut down. | 2016-06-21 16:12:20 GainCapital FIX Trading socket (100) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:12:20 GainCapital FIX Trading socket (100) | Shutdown and closed. | 2016-06-21 16:12:20 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:12:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:12:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:12:20 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:12:20 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:12:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:12:20 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:14:19 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:14:19 GainCapital FIX Trading socket (103) | Connected. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | Starting TLS 1.2 connection. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | SSL connection established. | 2016-06-21 16:14:20 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | Closed. No error. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | SSL has been shut down. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:14:20 GainCapital FIX Trading socket (103) | Shutdown and closed. | 2016-06-21 16:14:20 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:14:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:14:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:14:20 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:14:20 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 16:14:20 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:14:20 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:14:20 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:16:21 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:16:21 GainCapital FIX Trading socket (105) | Connected. | 2016-06-21 16:16:21 GainCapital FIX Trading socket (105) | Starting TLS 1.2 connection. | 2016-06-21 16:16:21 GainCapital FIX Trading socket (105) | SSL connection established. | 2016-06-21 16:16:22 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:16:22 GainCapital FIX Trading socket (105) | Closed. No error. | 2016-06-21 16:16:22 GainCapital FIX Trading socket (105) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:16:22 GainCapital FIX Trading socket (105) | SSL has been shut down. | 2016-06-21 16:16:22 GainCapital FIX Trading socket (105) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:16:22 GainCapital FIX Trading socket (105) | Shutdown and closed. | 2016-06-21 16:16:22 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:16:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:16:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:16:22 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:16:22 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:16:22 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:16:22 GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-06-21 16:18:22 GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-06-21 16:18:22 GainCapital FIX Trading socket (107) | Connected. | 2016-06-21 16:18:22 GainCapital FIX Trading socket (107) | Starting TLS 1.2 connection. | 2016-06-21 16:18:22 GainCapital FIX Trading socket (107) | SSL connection established. | 2016-06-21 16:18:22 GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:18:23 GainCapital FIX Trading socket (107) | Closed. No error. | 2016-06-21 16:18:23 GainCapital FIX Trading socket (107) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-21 16:18:23 GainCapital FIX Trading socket (107) | SSL has been shut down. | 2016-06-21 16:18:23 GainCapital FIX Trading socket (107) | SSL object has been freed. SSL state is now disconnected. | 2016-06-21 16:18:23 GainCapital FIX Trading socket (107) | Shutdown and closed. | 2016-06-21 16:18:23 GainCapital FIX Trading: Socket connection was closed without any logout messages sent or received. | 2016-06-21 16:18:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-06-21 16:18:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-06-21 16:18:23 GAIN Capital/OEC | Disconnected from the trading server. | 2016-06-21 16:18:23 GAIN Capital/OEC | Immediate disconnect from trading server detected. On next connect Logout will be sent first. | 2016-06-21 16:18:23 GAIN Capital/OEC | Disconnected. | 2016-06-21 16:18:23 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-21 16:18:23 |
[2016-06-21 17:07:51] |
These are the relevant messages while connecting to Gain Capital: GainCapital FIX Trading: Sending the Logon message. | 2016-06-21 16:06:12
GainCapital FIX Trading socket (94) | Closed. No error. | 2016-06-21 16:06:12 Refer to: http://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#ConnectionProblem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
