Date/Time: Mon, 25 Nov 2024 09:42:39 +0000
Control bar button to enable/disable study
View Count: 1932
[2016-06-21 15:39:19]
Stephan908 - Posts: 46
Hi, Is there a way to setup a button on the control bar so I can enable and disable a particular study? Like a button to show the previous close line or VWAP with a click of a button and take it off by clicking the button again? I did a search but didn't find the answer. Thanks.
[2016-06-21 17:18:14]
This cannot be done with a Control Bar button. However, there is a method to hide and show a study quickly in a Chart Region:
Refer to the documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#HidingShowingStudy
[2016-06-22 16:53:34]
Thanks for the info. Looks like it can only hide lower studies but I was hoping for a single click option to enable and disable studies on the main price graph. I do see a way to prevent a study from compressing the main graph so that should help. Thanks again! :)
[2024-03-17 12:59:15]
User547290 - Posts: 58
You can save a study group and then save the same study group without the study you don't want and bounce back and forth between the two. This will give you a way to basically turn off one study and turn it back on.
