Date/Time: Mon, 06 Jan 2025 10:13:39 +0000
Time error?
View Count: 926
[2016-06-21 14:34:38] |
User378205 - Posts: 28 |
I keep getting this message everyday. How can I stop this from happening again? Error setting the system Date-time: Windows error code 1314: A required privilege is not held by the client. | 2016-06-21 09:32:17 * HTTP connection to www.sierrachart.com:80 (42) | Closed. No error. | 2016-06-21 09:32:22 HTTP connection to www.sierrachart.com:80 (42) | Shutdown and closed. | 2016-06-21 09:32:22 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-21 09:32:34 HTTP connection to www.sierrachart.com:80 (43) | Connected. | 2016-06-21 09:32:34 Received Date-time from server. Delay adjusted UTC Date-time: 2016-06-21 14:32:34.084. Round-trip delay: 00:00:00.484 | 2016-06-21 09:32:35 Error setting the system Date-time: Windows error code 1314: A required privilege is not held by the client. | 2016-06-21 09:32:35 * HTTP connection to www.sierrachart.com:80 (43) | Closed. No error. | 2016-06-21 09:32:40 HTTP connection to www.sierrachart.com:80 (43) | Shutdown and closed. | 2016-06-21 09:32:40 |
[2016-06-21 17:01:46] |
You need to uncheck Global Settings >> General Settings >>Periodically Set System Date-Time from Server. Press OK. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-23 09:43:30] |
Bapovs01 - Posts: 24 |
Is there any way to cancel this in windows?
[2016-06-23 09:56:38] |
No.
