Date/Time: Mon, 06 Jan 2025 10:23:36 +0000
tick value for MJNK the Mini Nikkei 225 that trades on the OSE (Osaka Exchange)
View Count: 1153
[2016-06-20 20:41:16] |
User157806 - Posts: 71 |
I have a customer who is seeing a tick value that seems to be incorrect within the Sierra Charts platform see screenshot for reference. It seems to be showing 1000 yen per tick versus 500 yen per tick.
Date Time Of Last Edit: 2016-06-21 05:18:45
Private File |
[2016-06-21 05:18:27] |
This has been corrected. Follow the instructions here to update the Symbol Settings: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings You will then need to select Edit >> Refresh Log on the Trade Activity Log window to correct the values there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
