Date/Time: Mon, 06 Jan 2025 10:32:26 +0000
TradeWindowConfigFileName question
View Count: 649
[2016-06-20 06:47:32]
onnb - Posts: 662
sc.TradeWindowConfigFileName = "SimpleBracket.twconfig";
I understand I can set this outside the SetDefaults block.
So if I have following scenario
1. Study places an order. Before submitting the order, I do this - TradeWindowConfigFileName = "config1.twconfig"
2. Study then places a second order. Before submitting the other, I do this - TradeWindowConfigFileName = "config2.twconfig"
Will that generally work as expected?
Can I also do this - TradeWindowConfigFileName = "";
to disable this at some point?
[2016-06-20 07:25:42]
1, 2. Yes it should but test it.
This effectively does nothing:
[2016-06-20 16:10:31]
onnb - Posts: 662
Is there a way to "disable" it then?
What I mean is to tell SC to not use a configuration but use whatever the user has set in the trade panel.
[2016-06-20 17:09:51]
It depends what you want to disable. Are you referring to Attached Orders?
Date Time Of Last Edit: 2016-06-20 17:10:22
[2016-06-20 17:27:43]
onnb - Posts: 662
I just tested this and when I do this - TradeWindowConfigFileName = "config1.twconfig"
the values in the Trade Window actually change. That was a misunderstanding on my part.
Now I understand your question.
I don't think there are many ACSIL functions or settings that actually make changes in the GUI. I think the GUI settings are read only for the most part.
But now I get it ;)
[2016-06-20 17:35:30]
OK let us know if you have any other questions.
