Date/Time: Mon, 06 Jan 2025 09:23:43 +0000
list or print id # of all study/indicators and sub graph #s on a chart
View Count: 843
[2016-06-18 18:01:39] |
JohnR - User831573 - Posts: 307 |
I am in the process of creating my first alert. I want to eventually have logic in an alert that accesses multiple studies, which some have multiple subgraphs. In place of writing down each study ID and it's associated subgraph IDs, is there a way or place I can go to get a list of all of this for a chart window? I was planning on doing this in a simple alert. Should I be using a spreadsheet instead? TIA John Date Time Of Last Edit: 2016-06-18 19:41:00
[2016-06-18 23:33:46] |
This is not supported. However, in the Analysis >> Studies >> Studies to Graph list window you will see all of the study ID numbers listed. You can use the Spreadsheet System/Alert study if that would help you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
