Date/Time: Mon, 06 Jan 2025 10:22:49 +0000
Replaying in Trade DOM and replay speed
View Count: 1535
[2016-06-18 10:08:53] |
Cavalry3162 - Posts: 523 |
Hello SC, is there a way to enable chart replay in the trade dom? as it is right now, it fails to show any depth information. and, as a scalper, i am looking for size changes in the market depth. this is - right now - impossible as the resolution is way to low. a replay speed of 1 second isnt gonna cut it. would it be possible to implement a replay speed in the actual chart update interval? that would be really awesome! thank you, Andreas |
[2016-06-18 23:59:18] |
Replaying market depth data in the Trade DOM will be supported in the next release. In that release you will need to follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_ReplayChart.html#ReplayingTradeDOM Replays do occur at speeds less than one second. The Replay Chart documentation explains all of this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-19 00:01:42
