Date/Time: Mon, 06 Jan 2025 09:21:11 +0000
Trial to Test TD Ameritrade Feed With SC
View Count: 640
[2016-06-18 09:22:23]
User460061 - Posts: 1
Would I be able to test my TD Ameritrade data feed in a trial account? I'm trying to see if I can use this in conjunction with Sierra Chart
[2016-06-18 09:52:15]
Your account has been activated and/or reset.
If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu.
After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit".
Follow the TD Ameritrade instructions here:
https://www.sierrachart.com/index.php?page=doc/AmeriTrade.php
Date Time Of Last Edit: 2016-06-18 09:53:45
