Date/Time: Mon, 06 Jan 2025 10:25:10 +0000
Daily Range
View Count: 1299
[2016-06-17 15:13:57]
User497973 - Posts: 15
I'm looking for a way to display the current daily range on an intraday chart (just simply the current high minus the current low). And additionally if possible the ADR for the last few days.
I know it's possible if I have a daily chart open and then use the Study overlay indicator to link the indicator between the daily chart and the intraday chart.
Is there a way to do this without having the daily chart open? Maybe just have the simple value appear at the bottom left corner of the intraday chart?
Thanks You in Advance,
DS
[2016-06-17 17:54:36]
Refer to the documentation for Daily OHLC to do what you want:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137
And refer to Average Daily Range:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s347
You will require 2 charts for Average Daily Range.
