Date/Time: Mon, 06 Jan 2025 10:30:03 +0000
Copy SC settings to another Computer
View Count: 1529
[2016-06-17 12:41:57]
Meritus - Posts: 164
Hey Support,
Please can you direct me to or supply info about how I can transfer my existing SC workspace including chartbooks etc onto my laptop? My aim is simply to have the same setup on my laptop as I have on my main computer - ie I hope I dont have to re-build my chartbooks on my laptop SC.
Also I cannot remember my username or password as my SC opens automatically and I've had it a few years. Can you tell me where I find this info or how to change password if needed
Thanks in advance
[2016-06-17 13:04:52]
chisel - Posts: 23
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
[2016-06-17 13:29:24]
Thanks chisel
[2016-06-17 14:00:33]
chisel - Posts: 23
With SC open: help/account control panel
That should open a new webpage on the SC site with your account details.
[2016-06-17 16:41:41]
The information given previously is correct but nevertheless we are giving our own answer. Refer to this help topic:
Https://www.sierrachart.com/index.php?l=helpdetails15.html
Select Help >> Account Control Panel from within Sierra Chart.
