Date/Time: Sat, 11 Jan 2025 09:52:37 +0000
Delta divergence Alert tab
View Count: 1594
[2016-06-16 17:52:50]
User341584 - Posts: 44
I added the delta divergence study to a chart. I set my alerts up in alert manager. How ever when a delta divergence occurs and a candle is painted, I still dont get an audible alert to trigger?
Do I need to add a condition?
If I do need to add an alert condition, any help would be appreciated.
I've added a pic of my alert tab.
Thanks in advance.
M
Date Time Of Last Edit: 2016-06-16 17:53:21
imageCapture.PNG / V - Attached On 2016-06-16 17:52:42 UTC - Size: 17.15 KB - 385 views
[2016-06-16 18:04:59]
You definitely do have to specify an Alert Condition formula. Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php
This section may also be helpful:
http://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#WritingFormulasForStudiesWithoutObviousValues
[2016-06-17 00:32:13]
Thank you
Date Time Of Last Edit: 2016-06-17 01:25:44
[2016-06-17 12:39:33]
I thought I had this figured out, appearently not.
I added conditin, "=OR(ID9,SG2,ID9,SG3,)". But Im getting an error.
What Am I missing here?
Ive uploaded an image.
Anybody?
M
imageCapture.PNG / V - Attached On 2016-06-17 12:39:14 UTC - Size: 15.32 KB - 298 views
[2016-06-17 17:58:56]
Use:
=OR(ID9.SG2,ID9.SG3)
[2016-06-22 00:08:52]
I used the recommended formula for alert.
Still not getting anything audio?
Ive included 3 snips of what I have.
After this Im out of ideas?
Thanks for working with me on this.
M
Date Time Of Last Edit: 2016-06-22 00:09:03
imageCapture.PNG / V - Attached On 2016-06-22 00:08:37 UTC - Size: 17.79 KB - 378 views
imageCapture1.PNG / V - Attached On 2016-06-22 00:08:41 UTC - Size: 25.54 KB - 331 views
imageCapture2.PNG / V - Attached On 2016-06-22 00:08:45 UTC - Size: 16.81 KB - 305 views
[2016-06-22 00:30:20]
Sawtooth - Posts: 4147
Try this:
=OR(ID9.SG2>0,ID9.SG3>0)
Most studies output a 1 when true, but this study outputs a price.
To see what a study outputs, you can add the Spreadsheet Study study, and look in columns AA and above.
[2016-06-22 01:35:32]
It worked! Thank you sooo much !
[2016-11-30 20:04:51]
jmr5d - Posts: 1
This helped a bunch, was having the same problem, thanks!
