Date/Time: Mon, 06 Jan 2025 10:22:33 +0000
Flexible Renko Bars
View Count: 815
[2016-06-16 00:05:32]
User104164 - Posts: 19
I'd like to create a chart with Renko bar where say brick size for the bar is 5 but brick size for reversal bar is 10. Also would like to see wicks.
How this can be done?
Thanks.
[2016-06-16 01:02:21]
What you want are standard Renko bars. You can read about the definition here:
https://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html#Intro
The candlestick wicks can be enabled. The documentation explains that.
[2016-06-16 01:23:40]
Standard Renko doesn't work as it gives brick size SAME for both continuation and reversal bars. I need brick size (not counting wick or open offset) of reversal bar to have different brick (body) size then other bars.
Let me know.
Thanks.
[2016-06-16 03:49:57]
We understand what you want. This is not supported.
[2016-06-16 04:32:35]
Ok. Thanks.
