Date/Time: Mon, 06 Jan 2025 09:39:01 +0000
Multi Target Order with Trailing Stop
View Count: 843
[2016-06-15 19:00:42] |
dBassFour - Posts: 16 |
Hello, I've followed the "example 4" in the Same Trade Configuration Doc, but if my FIRST target is set to 4T, and the Trigger Offset is set to 4 Ticks- then if my order doesnt print at +4 Ticks, but the market does- it triggers my trailing stop before my order gets executed. What is the best way to accomplish the following? OCO 1 - Target 4 Ticks OCO 1 - STOP @ 8 Ticks OCO 2 - Target 8 Ticks OCO 2 - Trailing Stop at 8 Ticks, then once Order(OCO) 1 FILLS, it moves to breakeven +1 and continues to Trail at 4 Ticks behind Market price? I've tried for about 2 hours, but keep getting strange behavior of it triggering too early. I've read the Doc thoroughly, but I cant get around this +4 Trigger happening sometimes BEFORE my OCO 1 gets filled. Any ideas would be great! Dion http://www.sierrachart.com/image.php?Image=1466017296819.png Date Time Of Last Edit: 2016-06-15 19:03:50
[2016-06-15 20:04:34] |
Cavalry3162 - Posts: 523 |
your +4tick order do not get filled at +4ticks (roughly, i ignore the order queue) but on a +5 as it gotta tick through (bid/ask related). so you may end up setting your trigger to +5 andreas |
[2016-06-16 03:59:22] |
In the Attached Order settings we see you are not using a trailing stop but the Move to Breakeven for Stop settings are correct.
