Date/Time: Mon, 21 Sep 2026 18:24:15 +0000
[Programming Help] - problem : I do not know how do you retrieve the line in a text file.
View Count: 1823
| [2016-06-15 10:18:23] |
| User210074 - Posts: 63 |
I do not know how do you retrieve the line in a text file. I want to recover 1 in this txt file. #include <iostream> #include <string> #include <fstream> #include "sierrachart.h" #include <stdio.h> #include <time.h> using namespace std; SCDLLName("Test"); SCSFExport scsf_DTNS(SCStudyGraphRef sc) { if(sc.SetDefaults){ sc.GraphName="Test"; sc.StudyDescription="Test"; sc.FreeDLL = 1; sc.GraphRegion = 0; }//Fin de la fonction Defaut// ifstream Files("Z:\\Sierra_Chart\\Data\\Val.txt", ios::in);//Z:\\SC_Graphique_rithmic\\Data\\Val.txt" if(Files){ //sc.AddMessageToLog("File Open.", 1); string Lines; while ( getline(Files, Lines) ) { // ..... } Files.close(); return; }//Right else{ sc.AddMessageToLog("File Not Open.", 1); return; }//Wrong }//Fin de fonction// In Val.txt 1 // Line 1 How can i retrieved the line in the WHILE ? I don't Know ! |
| [2016-06-17 14:27:46] |
I test that But it doesn't work #include <iostream> #include <string> #include <fstream> #include "sierrachart.h" #include <stdio.h> #include <time.h> using namespace std; SCDLLName("Test"); SCSFExport scsf_DTNS(SCStudyGraphRef sc) { if(sc.SetDefaults){ sc.GraphName="Test"; sc.StudyDescription="Test"; sc.FreeDLL = 1; sc.GraphRegion = 0; } ifstream Files("Z:\\SC_Graphique_rithmic\\Data\\Val.txt", ios::in); if(Files){ //sc.AddMessageToLog("File Open.", 1); string Lines; while ( getline(Files, Lines) ) { std::stringstream Val(Lines); int Data, Value; std::string Data; if ( std::getline(Val, Data, ',') ) { Value = Data; } else { Value = ""; } } Files.close(); return; }//Right else{ sc.AddMessageToLog("File Not Open.", 1); return; }//Wrong } Error -- Starting build of Custom Studies Source files: DTS.cpp. -- 16:18:58 "Z:\SierraChart\CPPCompiler\bin\g++.exe" "Z:\SC_Graphique_rithmic\ACS_Source\DTS.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 -o "Z:\SC_Graphique_rithmic\Data\DTS.dll" Z:\SC_Graphique_rithmic\ACS_Source\DTS.cpp: In function 'void scsf_DTNS(SCStudyInterfaceRef)': Z:\SC_Graphique_rithmic\ACS_Source\DTS.cpp:23:34: error: variable 'std::stringstream ss' has initializer but incomplete type std::stringstream ss(Lines); ^ Z:\SC_Graphique_rithmic\ACS_Source\DTS.cpp:25:20: error: conflicting declaration 'std::string Data' std::string Data; ^ Z:\SC_Graphique_rithmic\ACS_Source\DTS.cpp:24:12: note: previous declaration as 'int Data' int Data, Valeur; ^ Z:\SC_Graphique_rithmic\ACS_Source\DTS.cpp:27:34: error: invalid conversion from 'const char*' to 'int' [-fpermissive] else { Valeur = ""; } ^ -- End of Build -- 16:19:00 |
| [2016-06-17 16:20:07] |
We do not provide programming help.
