Date/Time: Mon, 06 Jan 2025 09:24:59 +0000
Modify context drop down
View Count: 728
[2016-06-14 23:47:11]
aydex - Posts: 110
1. Is there a way in the UI to remove some of the options shown after a right click on the chart when trading on the chart?
2. Is there a way a "skilled" programmer could ....(same as above)
Is so, what file would need to be modified?
-j
[2016-06-15 17:21:51]
1. Yes this is done through the Global Settings menu. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeChartTradeMenu
2. No, this is not possible.
[2016-06-16 00:13:00]
aydex - Posts: 110
OK thanks
Is there a reason why Delete data and Studies can't be moved (and removed) to the left in this dialog?
imagesnip.PNG / V - Attached On 2016-06-16 00:12:29 UTC - Size: 15.4 KB - 235 views
[2016-06-16 04:07:36]
This is answered in the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeChartShortcutMenu
