Date/Time: Mon, 06 Jan 2025 09:39:46 +0000
Breakout Bars as chart bar period
View Count: 1815
[2016-06-14 06:23:24] |
User494206 - Posts: 44 |
Rockwell uses for their template 8 ticks breakout bars for the ES. How do I program Breakout Bars?
[2016-06-14 06:46:20] |
Are you referring to 8 tick Range bars?
[2016-06-14 09:48:56] |
You can see it on the head of the chart attached. The daily range average, stoploss and target ar not working eather. Do you know how to let them work?
Rockwell6132016.png / V - Attached On 2016-06-14 09:46:54 UTC - Size: 51.63 KB - 292 views |
[2016-06-14 10:55:28] |
These are Range bars. You just need to select Chart >> Chart Settings and use the Range Per Bar-Standard setting. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#RangeBarStandard Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-14 11:39:10] |
OK, and do you knoe how I let work the dialy range average stoploss and target? It is not working. It is in the chart left top
[2016-06-14 12:44:17] |
Sawtooth - Posts: 4145 |
The Daily Range Average requires a Daily chart in the chartbook that has the Bar Difference study, and a SMA based on it. Here is a chartbook example with the full setup: http://www.sierrachart.com/index.php?page=doc/AdditionalFiles.php Go to #22. |
[2016-06-14 17:15:14] |
Refer to the Rockwell Chartbook at item number 22 here: http://www.sierrachart.com/index.php?page=doc/AdditionalFiles.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
