Date/Time: Sat, 11 Jan 2025 21:02:19 +0000
Running two feeds on one install?
View Count: 864
[2016-06-13 15:24:39]
NGtrader - Posts: 12
Is it possible to run two data feeds on one install of Sierra, e.g. realtime futures data and then the other feed being spotfx and cfd?
Or do I need to do two separate installs like before with one for each data feed type?
Thanks.
Ed
[2016-06-13 16:53:37]
This can be done with a single installation of Sierra Chart.
You will see the Futures, Forex and CFD symbols listed in File >> Find Symbol.
If you do not, update Sierra Chart to the current version.
Date Time Of Last Edit: 2016-06-13 16:54:00
