Date/Time: Mon, 06 Jan 2025 09:26:54 +0000
"Formula resulted in an unexpected value type" Error
View Count: 1184
[2016-06-11 17:09:13] |
FFTrader - Posts: 180 |
I received the above error after I updated to v1427 ... see attached screen capture. ID2 is the Fisher Transform study. ID3 is Study Subgraphs Difference of the two outputs in the custom study MAMA (MAMA's SG1 and SG2). I want to roll it back to version 1426 as there were no errors before. Can you show me how to install previous versions? Just download and reinstall does not work ... kept saying that it is version 1427 and not 1426 (and still produces the above error). HELP?! Date Time Of Last Edit: 2016-06-11 17:10:30
Capture.JPG / V - Attached On 2016-06-11 16:57:41 UTC - Size: 90.21 KB - 337 views |
[2016-06-11 21:02:51] |
We will look into this. To go back to version 1426 simply follow the instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#Rollback It is very easy and reliable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-12 17:17:29] |
Ok ... rolling back.
[2016-06-12 19:33:42] |
I am away from my own Wifi but cannot seemed to rollback ... will keep trying.
[2016-06-12 22:10:46] |
There were a couple of problems relating to the installer. This is the reason for the problem. This is now solved. Try again following these instructions here: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate We apologize for the issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-13 00:53:58] |
I was able to follow the previous instructions to roll back to 1426 just now. Will try this new one too.
[2016-06-13 01:22:14] |
The correct instructions for rolling back are here: https://www.sierrachart.com/index.php?page=doc/download.php#Rollback Disregard the link given in post #5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-15 00:00:26] |
Internal note: Follow up.
[2016-06-15 08:50:55] |
The formula error problem will be resolved in the next release.
[2016-06-16 22:08:22] |
So I should try version v1429 now?
[2016-06-16 22:16:58] |
Actually, we thought we were going to be able to isolate and resolve the problem but we could not. If you could provide us your Chartbook which this occurs with, that might help us determine the source of the problem. You can privately attach it following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-17 01:43:18] |
I was having issues with all of them so here is one of them. This one was saved earlier in the day with v1426. See private attachment. I can still try version 1429? |
Private File |
[2016-06-17 10:15:27] |
You can try version 1429 but you may have this alert error message.
[2016-06-21 07:04:35] |
See if you encounter the problem when using version 1431. We tested your Chartbook and did not see the error.
[2016-06-21 18:33:19] |
Oh ok. Thx.
