Date/Time: Tue, 22 Sep 2026 09:26:42 +0000
intraday data file import question
View Count: 1320
[2016-06-09 21:16:42]
onnb - Posts: 666
just want to clarify something
I have an intraday data file in text format from CQG
I want to import it into SC for replay purposes.
I understand that in order to replay it needs to be in scid format.
I also understand I can import text based intraday files.
So question is this,
1. Can I import text based file and within SC convert it to scid for replay?
Or...
2. Do I need to convert to scid from outside SC and load it like any other scid file by placing it in the data folder and open a chart with the symbol name?
[2016-06-09 23:01:34]
1. Refer to:
http://www.sierrachart.com/index.php?page=doc/doc_ImportExport.html
2. No need to do like this.
[2016-06-10 00:07:46]
onnb - Posts: 666
got it
if I have CQG T&S which includes 4 types of records
T - trade
B/A - best bid/ask quotes
S - settlement
Assuming I do not need to import bid/ask quote, I would import only the T rows, yes?
Here is sample data.
The 5th column includes the type of row. I left it here just so you can see it. I understand that it does not need to be in there when importing.
Symbol  Date   Time   Price    Volume
TFU16  20160403  170000136  100000  B  5
TFU16  20160403  170000136  160000  A  1
TFU16  20160403  170514016  111300  A  20
TFU16  20160403  170514016  110300  B  20
TFU16  20160403  170643632  110350  B  20
TFU16  20160403  170728832  111250  A  20
TFU16  20160403  170738212  110300  B  20
TFU16  20160403  170809476  111200  A  20
TFU16  20160403  171347208  110250  B  20
TFU16  20160403  172322420  110250  B  20
TFU16  20160403  172322420  111200  A  20
TFU16  20160403  173027148  110720  B  4
TFU16  20160403  174807784  111150  A  20
TFU16  20160403  175322412  110720  B  4
TFU16  20160403  175322412  111150  A  20
TFU16  20160403  175753296  110930  B  4
TFU16  20160403  175753296  110930  T  4
[2016-06-10 02:59:23]
Unless you want to bid and ask data, you would just import the rows with the T.
Also the time format is not supported as it is. For what is supported, refer to:
http://www.sierrachart.com/index.php?page=doc/doc_TextCSVDataFormat.html#TimeFormat
Although it should be not much difficulty for us to add support for that particular time format. So we will do that.
[2016-10-08 10:20:56]
The latest prerelease of Sierra Chart now supports importing CQG time and sales data with a file extension of .TS.
Here is the updated documentation:
Exporting and Importing Intraday Data Files: Import and Load
Date Time Of Last Edit: 2016-10-08 10:27:07
