Date/Time: Sat, 04 Jan 2025 07:47:08 +0000
My Profile drawing isn't being uploaded to Range chart.
View Count: 708
[2016-06-09 01:15:58] |
User992108 - Posts: 31 |
Hello, I've tried to upload my Profile shaded zones: http://www.sierrachart.com/image.php?Image=1465433728304.png and put it on this Range chart here: http://www.sierrachart.com/image.php?Image=1465433770855.png . It isn't accepting the # drawing when I go to Chart Settings> Advanced Settings 2> Copy Charts Drawings. What do I do to make this work? ............Thank you |
[2016-06-09 01:41:31] |
Copying Chart Drawings from a TPO Profile chart to another chart is not going to work reliably. It is not supported.
[2016-06-09 01:42:54] |
However, this might work. It all depends upon the Date-Time mapping. It isn't accepting the # drawing when I go to Chart Settings> Advanced Settings 2> Copy Charts Drawings.
What precisely do you mean by this? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-09 02:02:44] |
I know some other people that when they highlight zones it will transfer their shaded TPO Profile to their chart as I've shown here. This is my TPO profile; http://www.sierrachart.com/image.php?Image=1465433728304.png and I want to put it on this Range chart here: http://www.sierrachart.com/image.php?Image=1465433770855.png . When I go to my chart: http://www.sierrachart.com/image.php?Image=1465433770855.png and go to Chart Settings> Advanced Settings 2> Copy Charts Drawings. it isn't taking the TPO profile chart drawings. |
[2016-06-09 02:03:52] |
How do I fix this problem?
[2016-06-09 02:06:03] |
What do you mean by......It all depends upon the Date-Time mapping? Can you help to set up the Date/Time mapping? |
[2016-06-09 05:04:47] |
There should not be a problem with this. We tested it and it does work. Review the documentation here for this: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#CopyChartDrawingsfromChart If there still is a problem we need to get your Chartbook by following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
