Date/Time: Mon, 06 Jan 2025 09:55:14 +0000
Price display format
View Count: 1328
[2016-06-08 19:54:52] |
User170575 - Posts: 221 |
Hello, Is there a place to set the default for the price display/tick size format and to uncheck the auto-set from datafeed as a default. I think I am missing some alerts on the low priced stocks that trades in 10th's of a penny. Many thanks, Cy |
[2016-06-09 05:12:50] |
Yes this is done through the Global Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php By default, Auto Set from Data Feed will be disabled as long as there are Symbol Settings defined for the symbol or symbol pattern. There is also a setting for this in the Global Symbol Settings for the symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-09 05:14:07
[2016-06-09 16:31:20] |
Thanks---so it must be done on a symbol by symbol basis only?
[2016-06-09 18:13:54] |
You need to use a Symbol Pattern: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#Instructions These patterns should already be listed. If not, follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings We see you are using TD Ameritrade. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-22 14:01:51] |
So if I have the price format changed and the tick format---shouldn't the order box see this?
[2016-06-22 14:37:08] |
what am I missing here---I updated the format---refreshed the ticker and no update---see attached plz
Attachment Deleted. |
[2016-06-22 17:13:27] |
You also need to apply the settings to existing charts following these instructions: http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
