Date/Time: Sat, 04 Jan 2025 08:08:14 +0000
Studies Help
View Count: 628
[2016-06-08 18:43:44]
KrisM2M - Posts: 6
I have two studies (shown on the attached image as M2M_MD and M2M_Swing_Index) that I am trying to correlate together to give me a single arrow to plot on the main price graph.
More then likely, It will be easier to see the attached image rather then attempt to explain by text. On the image you see large vertical yellow lines (which won't plot), but for this example allows you to see what I want as the trigger to then plot an arrow just above or below price (yellow arrows). The trigger is the M2M_MD and M2M_Swing_Index the same 'color' or indicating buyers/sellers.
I've been trying for some time to get this to work but I'm having a tough time having the study perform correctly.
Thanks,
Kris
imageExample.jpg / V - Attached On 2016-06-08 18:43:30 UTC - Size: 151.58 KB - 270 views
[2016-06-09 02:15:00]
To accomplish what you want, you need to use the Color Bar Based on Alert Condition study which also can draw arrows by the price bars:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s245
