Date/Time: Sat, 04 Jan 2025 07:41:47 +0000
Data for Forex and futures
View Count: 779
[2016-06-08 11:25:12] |
User598429 - Posts: 6 |
Hi, I am using Sierra's data service for forex. If I want to also get data for futures, do I need a separate account? I notice symbols for futures are also included in the listings under the Find Symbol option. Does the Sierra data feed allow access also to futures data? Or does it have to be paid for separately? Can I pay for just the one account and access bo9th forex and futures live data feeds? Thanks. Gerard |
[2016-06-08 17:33:14] |
You do not need a separate account. The Sierra Chart Exchange Data Feed which is a separate cost, does provide futures data: Sierra Chart Exchange Data Feed Do you have a futures trading account? For the reason why we ask, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-08 17:34:13
[2016-06-09 01:13:24] |
Hi, I am a little confused. I am getting the forex data now. So if I want futures data, do I need to pay extra over and above my current subscription payments? I do not have a futures trading account. If I need to pay extra for futures data, is it cheaper to go through a futures trading account? Thanks. Gerard |
[2016-06-09 01:44:42] |
You do have to pay extra for futures data or use a supported futures trading service which will include the data and is a more cost-effective option.
