Date/Time: Sat, 04 Jan 2025 08:22:01 +0000
Sierra live data feed with continuous contracts
View Count: 1059
[2016-06-08 09:23:09]
user40663 - Posts: 54
Hey
prior to today been using 1440m charts with cont contract chart set to none.
I would like to look further back on 1440m chart action as well as weekly, monthly etc so decided to experiment with cont contract settings.
I have read what is listed on sierra site regarding these but feel that i am missing something.
I want the historical intra price action and have tried all four setttings, but i don't know which one shows the true price.
What i want to know is which chart is showing correct pricing with no adjustments - i.e. back adjusting.
As you can see from pics supplied, when set to none, I have marked a lower low followed by higher low. I am assuming his is the actual price action.
The other 2 charts show lower low followed by lower low.
thanks
Private File
Private File
Private File
[2016-06-08 09:34:50]
You will want to use:
Continuous Futures Contract-Volume Based Rollover
[2016-06-08 10:39:32]
ok - so made the change as suggested and this was the result.
are you saying that this should be correct? obviously still differing from "none" setting chart.
thanks
Private File
[2016-06-08 17:42:54]
You need to understand what futures contract month you are looking at. Refer to:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#DisplayingRolloverDatesContractMonths
It is correct. It certainly will be different when not using a Continuous Futures Contract.
