Date/Time: Sat, 04 Jan 2025 08:01:16 +0000
How to make MARKER_ARROWUP point to bottom of bar?
View Count: 828
[2016-06-08 04:11:24]
skelcap - Posts: 139
I have similar code to the example scsf_UseToolExampleMarker:
Tool.DrawingType = DRAWING_MARKER;
Tool.MarkerType = MARKER_ARROWUP;
Tool.BeginValue = sc.Low[BarIndex];
I want the TIP of the arrow point exactly to the low of the bar. It seems that the default behavior is for the MIDDLE of the arrow shaft to lie on the BeginValue. I tried setting Tool.DrawFromEnd = 1 but that didn't seem to do anything. I tried to dynamically offset the BeginValue from the low as a multiple of the Tool.MarkerSize and TickSize but the result is not satisfactory since the placement varies according to the market and scale/barspacing. Wondering if there is an easier way I'm missing?
[2016-06-08 17:08:30]
You cannot do what you want using this Drawing Type.
You instead need to use a sc.Subgraph with the Draw Style set to Arrow Up:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_scSubgraph.html#scSubgraphDrawStyle
[2016-06-08 21:11:42]
Thanks actually that's what I tried first and I agree it yields arrow tip coinciding with BeginValue. I should have been clearer, what I actually want is one arrow pointing in to the BeginValue and another arrow in the same direction pointing out from the BeginValue, something like this so the tip of one arrow touches the tail of the other:
