Date/Time: Mon, 06 Jan 2025 09:43:34 +0000
How can you save multiple chart books ? so when you open sierra chart again,
View Count: 1381
[2016-06-08 02:34:14] |
User888596 - Posts: 2 |
How can you save multiple chart books ? so when you open sierra chart again next time, you do not need to open them again, they will automatically be loaded when you open your sierra chart, thanks |
[2016-06-08 05:28:54] |
All of this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-09 00:04:06] |
i960 - Posts: 360 |
I just realized this feature exists. Can we get "multiple selection" to work with it so I don't have to add my chartbooks 20 times? It's particularly annoying when I have them under a separate folder too, as it doesn't remember the last folder I used.
[2016-06-16 23:56:00] |
i960 - Posts: 360 |
Can we: 1. Get this to support "multiple selection" so that adding things to here is easier? 2. Make it actually work with a chartbook outside of the data folder? I keep my chartbooks in a subfolder called chartbook. This feature assumes a particular folder. |
[2016-06-17 17:53:55] |
User948528 - Posts: 108 |
^Yes please. And also: 3. Save multiple 'sets' of different chartbooks that can be opened together by loading one config file. |
