Date/Time: Sat, 04 Jan 2025 08:17:13 +0000
Chart numbers
View Count: 639
[2016-06-07 23:25:24]
User157806 - Posts: 71
Just had a simple question how do you add two symbols on one chart? For example I am trying to use the advance decline study to plot cash index of NYSE advance and decline and I need to add both symbols onto a single chart I know it has something to do with the chart numbers but I just forgot where to go to make that adjustment.
Johnny...
[2016-06-08 05:34:36]
Refer to:
Sierra Chart Market Statistics: Overlaying a Chart on Another Chart as a Study
Also the study you should be using is:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s151
It works with a single symbol.
