Date/Time: Sat, 04 Jan 2025 08:03:27 +0000
Move from one broker to another
View Count: 692
[2016-06-07 19:47:39] |
Laurent1 - Posts: 15 |
Hi, I am currently trading with DDT and have started a Sierra Chart trial. I am planning to move to AMP Futures if I really like the software. So my question is, will I be able to keep all my current setup and account login, or will I need to create it again? Thanks |
[2016-06-07 20:45:41] |
You will be able to keep the current set up and your same Sierra Chart account. You may need to change the symbols of the charts but that can be easily done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
