Date/Time: Sat, 04 Jan 2025 07:53:35 +0000
I am a new user, set up with AMP and sierra chart gives me a username and password
View Count: 577
[2016-06-07 19:42:06] |
User888596 - Posts: 2 |
When I logged in, connected, and tried to load my chartbooks, it shows that the simbol is unknown, how can I fix it? AMP uses CQG as data bundles |
[2016-06-08 05:35:34] |
Only use the symbols you find in File >> Find Symbol. Also, refer to: CQG Trading Platform Service: Market Data Authorizations for Symbols/Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
