Date/Time: Sat, 04 Jan 2025 07:02:53 +0000
Does anybody else have missing data for 6-6 9:45 (est) 1 min bar?
View Count: 817
[2016-06-07 15:17:30] |
Crtfyd - Posts: 281 |
I have edit/download data several times from a time prior, and have no data for the 9:45am (est) 1 min bar (any data from 9:45-9:46). Sometimes there's an error in the data, but typically its fixed. Its now ell over 24 hours later. I use TransACT data, Did anyone have missing data for that time frame? Was it just TransACT? Was it a glich in my charts? Everything else fine. Thx |
[2016-06-07 18:00:32] |
This data has now been filled in. Follow the instructions here to re-download the missing data: https://www.sierrachart.com/index.php?l=doc/doc_HistoricalIntradayData.html#RetryDownloadDataInChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
