Date/Time: Sat, 04 Jan 2025 07:34:23 +0000
Study overlay issue
View Count: 673
[2016-06-07 14:19:36] |
User533143 - Posts: 14 |
hi-when I add more than one study to a region, it distorts the studies. I forgot what box to check so all studies appear properly in same region. Thanks for any help.
[2016-06-07 18:03:19] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#OverlayingStudiesOnSameChartRegion Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
