Date/Time: Sat, 04 Jan 2025 08:24:18 +0000
lost chart
View Count: 637
[2016-06-07 13:39:15] |
User656410 - Posts: 12 |
Hello, Under my open chartbook file, I have 7 charts. I deleted one by mistake. Is it possible to retrieve it? Also, with those 7 charts, what is the best way to separate them so that I cam move them around my screens individually? Thank you |
[2016-06-07 18:04:29] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#RestoringPriorStateOfChartbook Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DetachingandAttachingChartWindows.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
