Date/Time: Sat, 04 Jan 2025 07:26:04 +0000
Rearranging Windows in a chart book
View Count: 922
[2016-06-06 14:44:50] |
User515197 - Posts: 5 |
How do you rearrange the sequence of window tabs to open at the bottom of a chart if possible?
[2016-06-06 17:33:59] |
This is done through Global Settings >> General Settings >> Tabs. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-07 02:35:32
[2016-06-07 02:02:38] |
I want to rearrange windows in a chart how do I do it?
[2016-06-07 02:59:25] |
We apologize for not being completely clear. Here is the relevant documentation to control the position of the Tabs: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#Tabs Also refer to: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#SelectingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
