Date/Time: Sat, 04 Jan 2025 07:29:05 +0000
Relative Volume Study and "Recalculate"
View Count: 829
[2016-06-06 13:37:24] |
User756998 - Posts: 1 |
When using the Relative Volume Study on the attached chart the first two bars seem to be inaccurate in real time. When "Recalculate" is done after the first two bars the results seem accurate for the rest of the session. The first chart is before the 09:30 EST open. The subsequent charts show each additional bar without a "Recalculate." The fifth chart is after a "Recalculate." After much experimentation it seems a "Recalculate" after the first two bars corrects the first two bars and subsequent "Recalculate"(s) are not required. As I am using this setup on numerous instruments is there a setting, or anything, to get the first two bars correct in real time without a "Recalculate?" Thanks! http://www.sierrachart.com/image.php?Image=1465218704462.png http://www.sierrachart.com/image.php?Image=1465219862809.png http://www.sierrachart.com/image.php?Image=146521998250.png http://www.sierrachart.com/image.php?Image=146522010395.png http://www.sierrachart.com/image.php?Image=146522013310.png |
[2016-06-06 17:37:06] |
We will look into this as soon as we can.
