Date/Time: Sat, 04 Jan 2025 07:38:35 +0000
Trading/data in the 2nd instance with True RT IB updates
View Count: 756
[2016-06-06 06:52:32]
User754985 - Posts: 109
In the main instance, I am using 5-sec True RT data from IB to feed into my strategies.
However, in the second instance launched from the main, charts get updated with just RT IB data, every IB tick (not once in 5sec)
How can to make this 2nd instance work similarly to the 1st?
[2016-06-06 06:57:59]
This is not supported and will not be in the future.
[2016-06-06 07:03:27]
What will not be supported?
Shall I launch a separate instance (i.e. not from the main?) to make it work right now?
[2016-06-06 07:04:51]
This will not be supported:
If you use another instance of Sierra Chart connected directly to Interactive Brokers, that will work.
