Date/Time: Sat, 04 Jan 2025 07:06:57 +0000
No Intraday Data for Symbol TN.XCME_F TN (U16)
View Count: 848
[2016-06-06 06:31:37]
Meritus - Posts: 164
Hey Support,
On Friday I was able to successfully open intraday charts for the CBOT Fin Futures symbol TN ~ CME_F 10yr Ultra Note in the September 16 contract. Tha data disappeared from the chart over the weekend and I thought it odd but assumed it would be fine again when the market opened on Sunday night/monday morning. There is still no intraday data displaying. It will only allow me to see a historical daily chart. I have copied and pasted a selection from the Message Log which I hope may help identify the issue. Thanks in advance
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 01:16:37
TN.XCME_F TN (U16).CME_F 120 Min #2 | Reloading chart. | 2016-06-06 01:16:37
TN.XCME_F TN (U16).CME_F 120 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 01:16:37
CTS FIX Historical Data socket (12) | Closed. No error. | 2016-06-06 01:17:07
CTS FIX Historical Data socket (12) | SSL shutdown indicates not able to send 'close notify'. | 2016-06-06 01:17:07
CTS FIX Historical Data socket (12) | SSL has been shut down. | 2016-06-06 01:17:07
CTS FIX Historical Data socket (12) | SSL object has been freed. SSL state is now disconnected. | 2016-06-06 01:17:07
CTS FIX Historical Data socket (12) | Shutdown and closed. | 2016-06-06 01:17:07
CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2016-06-06 01:17:07
CTS FIX Historical Data: Disconnected. | 2016-06-06 01:17:07
[2016-06-06 06:59:26]
I forgot to mention that SC WILL let me open and view an intraday chart for the JUNE 16 contract but not SEP and as you know, SEP is now the front month. Thks
[2016-06-06 07:01:02]
For the missing Intraday data issue, refer to:
https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#MissingOrIncompleteIntradayChartData
We cannot answer the question about why you are not getting historical Intraday data from the CTS system unless we see the entire Message Log.
Provide a copy of the Message Log, by following these instructions:
http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog
For reference, you have a question about this symbol: TN.XCME_F TN (U16).CME_F
Date Time Of Last Edit: 2016-06-06 07:01:32
[2016-06-06 07:28:01]
Reading Internal Order ID file. | 2016-06-06 02:25:34
Reading Trade Orders file. | 2016-06-06 02:25:34
Reading Trade Positions file. | 2016-06-06 02:25:34
Software version: 1420 | 2016-06-06 02:25:34
Uses New Spreadsheets | 2016-06-06 02:25:34
Usage end date: 2016-07-04 | 2016-06-06 02:25:34
Enabled for: Advanced Features. | 2016-06-06 02:25:34
Enabled for: Sierra Chart Historical Data Service. | 2016-06-06 02:25:34
Allow Support for Sierra Chart Data Feeds is disabled. | 2016-06-06 02:25:34
Current selected Data/Trading service: CTS T4 FIX | 2016-06-06 02:25:34
Chart Update Interval: 800 | 2016-06-06 02:25:34
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-06-06 02:25:34
2016-06-06 08:25:38 Local computer time | 2016-06-06 02:25:34
2016-06-06 07:25:38 Local computer time in UTC | 2016-06-06 02:25:34
2016-06-06 02:25:38 Local computer time in SC Time Zone | 2016-06-06 02:25:34
2016-06-06 07:25:36 Server time in UTC | 2016-06-06 02:25:34
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-06-06 02:25:34
Program path: C:\SierraChart\ | 2016-06-06 02:25:34
Data Files path: C:\Users\capitaleast\Documents\New folder\SC2\ | 2016-06-06 02:25:34
OS Version Number: 6.2 | 2016-06-06 02:25:34
Locale Setting: C | 2016-06-06 02:25:34
Checking for new symbol settings for cts | 2016-06-06 02:25:34
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-06-06 02:25:34
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-06-06 02:25:34
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-06-06 02:25:34
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-06-06 02:25:34
Symbol settings are up-to-date for cts | 2016-06-06 02:25:34
Files to Open on Start up | Opening file: bond spreads reverse.cht | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for ZN.20160900.CME_F | 2016-06-06 02:25:41
ZN.20160900.CME_F 30 Sec #5 | Reloading chart. | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for ZB.20160900.CME_F | 2016-06-06 02:25:41
ZB.20160900.CME_F 30 Sec #8 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Weekly #14 | Reloading chart. | 2016-06-06 02:25:41
Zb.20160900.CME_F Daily #1 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F 120 Min #4 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Daily #6 | Reloading chart. | 2016-06-06 02:25:41
GBPCAD Weekly #7 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F 120 Min #10 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F 30 Sec #11 | Reloading chart. | 2016-06-06 02:25:41
ZN.20160900.CME_F 30 Sec #12 | Reloading chart. | 2016-06-06 02:25:41
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 02:25:41
Files to Open on Start up | Opening file: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
Zb.20160900.CME_F Daily #13 | Reloading chart. | 2016-06-06 02:25:41
Zn.20160900.CME_F Daily #15 | Reloading chart. | 2016-06-06 02:25:41
Files to Open on Start up | Opening file: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F Daily #2 | Reloading chart. | 2016-06-06 02:25:41
ZN.20160900.CME_F 30 Sec #3 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 120 Min #10 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F Daily #5 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 30 Sec #6 | Reloading chart. | 2016-06-06 02:25:41
ZN.20160900.CME_F 30 Sec #7 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F Weekly #8 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 120 Min #9 | Reloading chart. | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (U16).CME_F | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #11 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #12 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #13 | Reloading chart. | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #14 | Reloading chart. | 2016-06-06 02:25:41
Files to Open on Start up | Opening file: BoB.cht | 2016-06-06 02:25:41
ZB.20160900.CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for UB.20160900.CME_F | 2016-06-06 02:25:41
UB.20160900.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 02:25:41
uB.20160900.CME_F 60 Min #6 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F 30 Sec #5 | Reloading chart. | 2016-06-06 02:25:41
UB.20160900.CME_F 30 Sec #7 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160900.CME_F Daily #8 | Reloading chart. | 2016-06-06 02:25:41
uB.20160900.CME_F 60 Min #10 | Reloading chart. | 2016-06-06 02:25:41
Files to Open on Start up | Opening file: M6 BoB.cht | 2016-06-06 02:25:41
ZB.20160600.CME_F 30 Sec #1 | Reloading chart. | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for UB.20160600.CME_F | 2016-06-06 02:25:41
UB.20160600.CME_F 30 Sec #2 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160600.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:25:41
ZB.20160600.CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:25:41
CTS T4 FIX | Using primary service for historical data for uB.20160600.CME_F | 2016-06-06 02:25:41
uB.20160600.CME_F 60 Min #6 | Reloading chart. | 2016-06-06 02:25:41
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-06-06 02:25:41
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-06-06 02:25:41
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-06-06 02:25:41
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-06-06 02:25:41
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:41
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 30 Sec #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 02:25:41
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 120 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 30 Sec #6 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 02:25:41
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:41
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:41
TN.XCME_F TN (u16).CME_F 120 Min #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (u16).CME_F.scid | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #12 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #13 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 02:25:41
Chart #7 has tagged chart #5 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:41
Chart #7 has tagged chart #8 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:41
TN.XCME_F TN (U16).CME_F 1 Min #14 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Users\capitaleast\Documents\New folder\SC2\TN.XCME_F TN (U16).CME_F.scid | 2016-06-06 02:25:41
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:25:41
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:25:41
Chart #5 has tagged chart #8 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:25:41
Chart #5 has tagged chart #9 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:25:41
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
HD Request # 2 | Downloading Historical Daily chart data for ZB.20160900.CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 02:25:50
HD Request # 2 | Requesting historical Daily data for ZBU16 starting at 2016-06-02 | 2016-06-06 02:25:50
HTTP connection to ds01.ddfplus.com:80 (0) | Resolved address ds01.ddfplus.com to IP 8.18.161.123. | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Using Bid/Ask average for last trade price for GBPCAD | 2016-06-06 02:25:50
HD Request # 3 | Downloading Historical Daily chart data for GBPCAD. Starting date: 2016-06-03. Service: fxcm | 2016-06-06 02:25:50
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2016-06-06 02:25:50
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26. | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
HTTP connection to ds01.ddfplus.com:80 (4) | Connected. | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Socket (5) | Connected. | 2016-06-06 02:25:50
HD Request # 3 | Sending historical data logon request message. | 2016-06-06 02:25:50
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:50
CTS FIX - Connecting to CTS Live server fix.t4login.com:10443 | 2016-06-06 02:25:50
CTS FIX - Firm: Dorman | 2016-06-06 02:25:50
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:50
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:50
HD Request # 3 | Requesting historical Daily data starting at 2016-06-03. | 2016-06-06 02:25:50
HD Request # 3 | Decompressing data. | 2016-06-06 02:25:50
HD Request # 3 | Receiving historical Daily data for GBPCAD starting at 2016-06-03 | 2016-06-06 02:25:50
HD Request # 3 | Writing historical Daily data to the file GBPCAD.dly | 2016-06-06 02:25:50
Socket (5) | Shutdown and closed. | 2016-06-06 02:25:50
The network socket for historical data has been closed. | 2016-06-06 02:25:50
CTS FIX socket (0) | Resolved address fix.t4login.com to IP 69.44.110.106. | 2016-06-06 02:25:50
HD Request # 2 | Receiving historical Daily data for ZB.20160900.CME_F starting at 2016-06-03 | 2016-06-06 02:25:50
HD Request # 2 | Writing historical Daily data to the file ZB.20160900.CME_F.dly | 2016-06-06 02:25:50
HD Request # 2 | Received 3 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for ZB.20160900.CME_F | 2016-06-06 02:25:50
HD Request # 2 | Daily download COMPLETE for ZB.20160900.CME_F. Completion time: 1s. Unique request ID: 1 | 2016-06-06 02:25:50
Removed historical data download ID 1 | 2016-06-06 02:25:50
HD Request # 3 | Received 2 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for GBPCAD | 2016-06-06 02:25:50
HD Request # 3 | Daily download COMPLETE for GBPCAD. Completion time: 1s. Unique request ID: 2 | 2016-06-06 02:25:50
Removed historical data download ID 2 | 2016-06-06 02:25:50
HD Request # 4 | Downloading Historical Daily chart data for Zn.20160900.CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 02:25:50
HD Request # 4 | Requesting historical Daily data for ZNU16 starting at 2016-06-02 | 2016-06-06 02:25:50
TN.XCME_F TN (u16).CME_F Daily #5 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:50
TN.XCME_F TN (u16).CME_F Weekly #8 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #8 | Reloading chart. | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 02:25:50
CTS FIX socket (6) | Connected. | 2016-06-06 02:25:50
CTS FIX socket (6) | Starting TLS 1.0 connection. | 2016-06-06 02:25:50
HD Request # 4 | Receiving historical Daily data for Zn.20160900.CME_F starting at 2016-06-03 | 2016-06-06 02:25:50
HD Request # 4 | Writing historical Daily data to the file Zn.20160900.CME_F.dly | 2016-06-06 02:25:50
HD Request # 4 | Received 3 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for Zn.20160900.CME_F | 2016-06-06 02:25:50
HD Request # 4 | Daily download COMPLETE for Zn.20160900.CME_F. Completion time: 0s. Unique request ID: 3 | 2016-06-06 02:25:50
Removed historical data download ID 3 | 2016-06-06 02:25:50
Intraday data recording state for symbol ZB.20160600.CME_F is set to download 'Pending'. | 2016-06-06 02:25:50
HD Request # 5 | Downloading Intraday chart data for ZB.20160600.CME_F to the file ZB.20160600.CME_F.scid. Service: cbot | 2016-06-06 02:25:50
HD Request # 5 | Download start Date-Time: 2016-06-06 02:13:16.000 | 2016-06-06 02:25:50
HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2016-06-06 02:25:50
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133. | 2016-06-06 02:25:50
HD Request # 6 | Downloading Historical Daily chart data for ZB.20160600.CME_F. Starting date: 2016-06-03. Service: cts | 2016-06-06 02:25:50
HD Request # 6 | Requesting historical Daily data for ZBM16 starting at 2016-06-02 | 2016-06-06 02:25:50
Socket (7) | Connected. | 2016-06-06 02:25:50
HD Request # 5 | Sending historical data logon request message. | 2016-06-06 02:25:50
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2016-06-06 02:13:16. Record interval: 1. Symbol: ZBM16 | 2016-06-06 02:25:50
HD Request # 5 | Decompressing data. | 2016-06-06 02:25:50
HD Request # 5 | Receiving Intraday data for ZB.20160600.CME_F starting at 2016-06-06 02:13:16 | 2016-06-06 02:25:50
HD Request # 5 | Timestamp of first Intraday data file record written: 2016-06-06 02:13:16 | 2016-06-06 02:25:50
Socket (7) | Shutdown and closed. | 2016-06-06 02:25:50
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 02:25:50
CTS FIX socket (6) | SSL connection established. | 2016-06-06 02:25:50
HD Request # 6 | Receiving historical Daily data for ZB.20160600.CME_F starting at 2016-06-03 | 2016-06-06 02:25:50
HD Request # 6 | Writing historical Daily data to the file ZB.20160600.CME_F.dly | 2016-06-06 02:25:50
HD Request # 6 | Received 3 records from 2016-06-03 00:00:00 to 2016-06-06 00:00:00 (4.0 days) and wrote 2 records for ZB.20160600.CME_F | 2016-06-06 02:25:50
HD Request # 6 | Daily download COMPLETE for ZB.20160600.CME_F. Completion time: 1s. Unique request ID: 5 | 2016-06-06 02:25:50
Removed historical data download ID 5 | 2016-06-06 02:25:50
HD Request # 5 | Historical data for ZB.20160600.CME_F is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2016-06-06 02:25:50
HD Request # 5 | Received 1 record from 2016-06-06 02:13:16 to 2016-06-06 02:13:16 (0.0 seconds) and wrote 1 record for ZB.20160600.CME_F | 2016-06-06 02:25:50
HD Request # 5 | Intraday download COMPLETE for ZB.20160600.CME_F. Completion time: 1s. Unique request ID: 4 | 2016-06-06 02:25:50
Removed historical data download ID 4 | 2016-06-06 02:25:50
ZB.20160900.CME_F Daily #6 | Reloading chart. | 2016-06-06 02:25:50
GBPCAD [M] Weekly #7 | Reloading chart. | 2016-06-06 02:25:53
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 02:25:53
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 02:25:53
ZB.20160900.CME_F Weekly #14 | Reloading chart. | 2016-06-06 02:25:53
Zb.20160900.CME_F Daily #1 | Reloading chart. | 2016-06-06 02:25:53
Zb.20160900.CME_F Daily #13 | Reloading chart. | 2016-06-06 02:25:53
Zn.20160900.CME_F Daily #15 | Reloading chart. | 2016-06-06 02:25:53
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 02:25:53
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:25:53
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:25:53
ZB.20160600.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:25:53
ZB.20160600.CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:25:53
CTS FIX: Sending the Logon message. | 2016-06-06 02:25:53
CTS FIX | FIX version: 4.3.55.2 | 2016-06-06 02:25:54
CTS T4 FIX | Connected to data and trading server. | 2016-06-06 02:25:54
CTS T4 FIX | Starting real-time market data updates for: TN.XCME_F TN (u16).CME_F. ID: 1 | 2016-06-06 02:25:54
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:25:54
Intraday data recording state for symbol TN.XCME_F TN (u16).CME_F is set to download 'Pending'. | 2016-06-06 02:25:54
Market data subscription status is not known while delaying historical data download for symbol: TN.XCME_F TN (u16).CME_F | 2016-06-06 02:25:54
Delaying start of download for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:25:54
CTS T4 FIX | Starting real-time market data updates for: ZN.20160900.CME_F. ID: 2 | 2016-06-06 02:25:54
CTS T4 FIX | Using primary service for historical data for ZN.20160900.CME_F | 2016-06-06 02:25:54
Intraday data recording state for symbol ZN.20160900.CME_F is set to download 'Pending'. | 2016-06-06 02:25:54
CTS T4 FIX | Sending security definition request for symbol ZN.20160900.CME_F | 2016-06-06 02:25:54
CTS T4 FIX | Starting real-time market data updates for: UB.20160600.CME_F. ID: 3 | 2016-06-06 02:25:54
CTS T4 FIX | Using primary service for historical data for UB.20160600.CME_F | 2016-06-06 02:25:54
Intraday data recording state for symbol UB.20160600.CME_F is set to download 'Pending'. | 2016-06-06 02:25:54
CTS T4 FIX | Starting real-time market data updates for: ZB.20160900.CME_F. ID: 4 | 2016-06-06 02:25:54
CTS FIX: Received Account List collateral report. | 2016-06-06 02:25:54
CTS FIX: Subscribing to account: 45* | 2016-06-06 02:25:54
Supported exchange: L_J (Euronext Index Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_IC (ICE EU Futures) | 2016-06-06 02:25:54
Supported exchange: L_Y (Euronext Commodity Futures) | 2016-06-06 02:25:54
Supported exchange: CME_ELE (NYMEX Power Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_WOp (ICE Canada Options) | 2016-06-06 02:25:54
Supported exchange: L_YOp (Euronext Commodity Options) | 2016-06-06 02:25:54
Supported exchange: E_INXOp (Eurex Index Options) | 2016-06-06 02:25:54
Supported exchange: CME_FRE (NYMEX Freight Futures) | 2016-06-06 02:25:54
Supported exchange: CME_KOp (KCBT Options) | 2016-06-06 02:25:54
Supported exchange: CME_HoOp (CME Housing Options) | 2016-06-06 02:25:54
Supported exchange: E_FITOp (Eurex Interest Rate Options) | 2016-06-06 02:25:54
Supported exchange: ICE_ICOp (ICE EU Options) | 2016-06-06 02:25:54
Supported exchange: ICE_FOp (ICE EU Financial Options) | 2016-06-06 02:25:54
Supported exchange: ICE_CO (ICE US Commodity Futures) | 2016-06-06 02:25:54
Supported exchange: CME_COAL (NYMEX Coal Futures) | 2016-06-06 02:25:54
Supported exchange: CME_COp (CBOT Commodity Options) | 2016-06-06 02:25:54
Supported exchange: CME_EqOp (CME Equity Options) | 2016-06-06 02:25:54
Supported exchange: E_VOL (Eurex Volatility Futures) | 2016-06-06 02:25:54
Supported exchange: CME_CL (NYMEX CrudeOil Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_IN (ICE US Index Futures) | 2016-06-06 02:25:54
Supported exchange: CME_Fo (CME Foreign Exchange Futures) | 2016-06-06 02:25:54
Supported exchange: CME_Ho (CME Housing Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_INOp (ICE US Index Options) | 2016-06-06 02:25:54
Supported exchange: CME_AgOp (CME Agricultural Options) | 2016-06-06 02:25:54
Supported exchange: CME_In (CME Interest Rate Futures) | 2016-06-06 02:25:54
Supported exchange: E_CUR (Eurex Currency Futures) | 2016-06-06 02:25:54
Supported exchange: E_FBDOp (Eurex Fixed Income Options) | 2016-06-06 02:25:54
Supported exchange: CME_CO (COMEX Futures) | 2016-06-06 02:25:54
Supported exchange: CME_Ag (CME Agricultural Futures) | 2016-06-06 02:25:54
Supported exchange: CME_EOp (CBOT Equity Options) | 2016-06-06 02:25:54
Supported exchange: CME_C (CBOT Commodity Futures) | 2016-06-06 02:25:54
Supported exchange: CME_F (CBOT Financial Futures) | 2016-06-06 02:25:54
Supported exchange: CME_E (CBOT Equity Futures) | 2016-06-06 02:25:54
Supported exchange: CME_K (KCBT Futures) | 2016-06-06 02:25:54
Supported exchange: CME_O (MGEX Futures) | 2016-06-06 02:25:54
Supported exchange: CME_FOp (CBOT Financial Options) | 2016-06-06 02:25:54
Supported exchange: ICE_MOp (ICE US Metals Options) | 2016-06-06 02:25:54
Supported exchange: E_INX (Eurex Index Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_M (ICE US Metals Futures) | 2016-06-06 02:25:54
Supported exchange: CME_OOp (MGEX Options) | 2016-06-06 02:25:54
Supported exchange: CME_COALOp (NYMEX Coal Options) | 2016-06-06 02:25:54
Supported exchange: ICE_CU (ICE US Currency Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_C (ICE EU Commodity Futures) | 2016-06-06 02:25:54
Supported exchange: CME_NG (NYMEX NatGas Futures) | 2016-06-06 02:25:54
Supported exchange: CME_CLOp (NYMEX CrudeOil Options) | 2016-06-06 02:25:54
Supported exchange: E_INT (Eurex Interest Rate Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_F (ICE EU Financial Futures) | 2016-06-06 02:25:54
Supported exchange: CME_NYOp (NYMEX Options) | 2016-06-06 02:25:54
Supported exchange: CME_We (CME Weather Futures) | 2016-06-06 02:25:54
Supported exchange: CME_REFOp (NYMEX Refined Products Options) | 2016-06-06 02:25:54
Supported exchange: CME_PET (NYMEX NGL/Petrochemicals Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_W (ICE Canada Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_COOp (ICE US Commodity Options) | 2016-06-06 02:25:54
Supported exchange: E_CUROp (Eurex Currency Options) | 2016-06-06 02:25:54
Supported exchange: CME_PETOp (NYMEX NGL/Petrochemicals Options) | 2016-06-06 02:25:54
Supported exchange: E_BND (Eurex Fixed Income Futures) | 2016-06-06 02:25:54
Supported exchange: CME_COOp (COMEX Options) | 2016-06-06 02:25:54
Supported exchange: LME_ME (LME Metal Futures) | 2016-06-06 02:25:54
Supported exchange: LME_PL (LME Plastic Futures) | 2016-06-06 02:25:54
Supported exchange: ICE_COp (ICE EU Commodity Options) | 2016-06-06 02:25:54
Supported exchange: CME_InOp (CME Interest Rate Options) | 2016-06-06 02:25:54
Supported exchange: CME_ELEOp (NYMEX Power Options) | 2016-06-06 02:25:54
Supported exchange: CME_Eq (CME Equity Futures) | 2016-06-06 02:25:54
Supported exchange: CBOE_CFE (CFE) | 2016-06-06 02:25:54
Supported exchange: CME_NGOp (NYMEX NatGas Options) | 2016-06-06 02:25:54
Supported exchange: CME_NY (NYMEX Futures) | 2016-06-06 02:25:54
Supported exchange: CME_FoOp (CME Foreign Exchange Options) | 2016-06-06 02:25:54
Supported exchange: CME_REF (NYMEX Refined Products Futures) | 2016-06-06 02:25:54
Supported exchange: LME_IN (LME Index Futures) | 2016-06-06 02:25:54
Symbol Error - TN.XCME_F TN (u16).CME_F is unknown, unavailable, or improperly formatted. CTS FIX: Received market data reject: (0) Market is not available | 2016-06-06 02:25:54
CTS T4 FIX | Received matching security definition for symbol ZN.20160900.CME_F. Subscribing to data. | 2016-06-06 02:25:54
CTS T4 FIX | Received 1 security definitions for underlying symbol ZN | 2016-06-06 02:25:54
CTS T4 FIX | Using primary service for historical data for ZB.20160900.CME_F | 2016-06-06 02:25:54
Intraday data recording state for symbol ZB.20160900.CME_F is set to download 'Pending'. | 2016-06-06 02:25:54
HD Request # 7 | Downloading Intraday chart data for TN.XCME_F TN (u16).CME_F to the file TN.XCME_F TN (u16).CME_F.scid. Service: cts | 2016-06-06 02:25:54
HD Request # 7 | Download start Date-Time: 2015-12-09 01:25:54.000 | 2016-06-06 02:25:54
CTS FIX Historical Data - Connecting to Historical data server fix-chart.t4login.com:10443 | 2016-06-06 02:25:54
Using Bid/Ask average for last trade price for GBPCAD | 2016-06-06 02:25:54
SC DTC Data | Starting real-time market data updates for: GBPCAD. ID: 5 | 2016-06-06 02:25:54
SC DTC Data | Connecting to the server ds5.sierracharts.com. Port 443 | 2016-06-06 02:25:54
Subscribing to common currency symbol for profit/loss currency calculations. Symbol: USDCAD | 2016-06-06 02:25:54
Using Bid/Ask average for last trade price for USDCAD | 2016-06-06 02:25:54
SC DTC Data | Starting real-time market data updates for: USDCAD. ID: 6 | 2016-06-06 02:25:54
CTS T4 FIX | Starting real-time market data updates for: ZB.20160600.CME_F. ID: 7 | 2016-06-06 02:25:54
CTS T4 FIX | Starting real-time market data updates for: uB.20160900.CME_F. ID: 8 | 2016-06-06 02:25:54
CTS T4 FIX | Using primary service for historical data for uB.20160900.CME_F | 2016-06-06 02:25:54
Intraday data recording state for symbol uB.20160900.CME_F is set to download 'Pending'. | 2016-06-06 02:25:54
Intraday data recording state for symbol ZB.20160600.CME_F is set to download 'Pending'. | 2016-06-06 02:25:54
CTS FIX Historical Data socket (0) | Resolved address fix-chart.t4login.com to IP 208.116.215.116. | 2016-06-06 02:25:54
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106. | 2016-06-06 02:25:54
HD Request # 8 | Downloading Intraday chart data for ZB.20160600.CME_F to the file ZB.20160600.CME_F.scid. Service: cbot | 2016-06-06 02:25:54
HD Request # 8 | Download start Date-Time: 2016-06-06 02:13:16.000 | 2016-06-06 02:25:54
HD Request # 8 | Using server: scdf1.sierracharts.com port 10149 | 2016-06-06 02:25:54
Socket (9) | Connected. | 2016-06-06 02:25:54
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131. | 2016-06-06 02:25:54
SC DTC Data | Connected to server. | 2016-06-06 02:25:54
SC DTC Data | Sending Encoding Request to server | 2016-06-06 02:25:54
CTS FIX Historical Data socket (8) | Connected. | 2016-06-06 02:25:54
CTS FIX Historical Data socket (8) | Starting TLS 1.0 connection. | 2016-06-06 02:25:54
CTS FIX: Received 'Account Update/Balance Data' collateral report. | 2016-06-06 02:25:54
Zn.20160900.CME_F Daily #15 | Reloading chart. | 2016-06-06 02:25:57
Socket (10) | Connected. | 2016-06-06 02:25:57
HD Request # 8 | Sending historical data logon request message. | 2016-06-06 02:25:57
SC DTC Data | Setting DTC Encoding to Binary VLS | 2016-06-06 02:25:57
SC DTC Data | Sending logon request message. | 2016-06-06 02:25:57
CTS T4 FIX | Sending security definition request for symbol UB.20160600.CME_F | 2016-06-06 02:25:57
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2016-06-06 02:13:16. Record interval: 1. Symbol: ZBM16 | 2016-06-06 02:25:57
HD Request # 8 | Decompressing data. | 2016-06-06 02:25:57
HD Request # 8 | Receiving Intraday data for ZB.20160600.CME_F starting at 2016-06-06 02:13:16 | 2016-06-06 02:25:57
HD Request # 8 | Timestamp of first Intraday data file record written: 2016-06-06 02:13:16 | 2016-06-06 02:25:57
Socket (10) | Shutdown and closed. | 2016-06-06 02:25:57
The network socket for historical data has been closed. | 2016-06-06 02:25:57
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:25:57
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:25:57
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:25:57
HD Request # 8 | Received 1 record from 2016-06-06 02:13:16 to 2016-06-06 02:13:16 (0.0 seconds) and wrote 1 record for ZB.20160600.CME_F | 2016-06-06 02:25:57
HD Request # 8 | Intraday download COMPLETE for ZB.20160600.CME_F. Completion time: 3s. Unique request ID: 12 | 2016-06-06 02:25:57
Removed historical data download ID 12 | 2016-06-06 02:25:57
Real-time Intraday chart data file updates started for ZB.20160600.CME_F | 2016-06-06 02:25:57
Intraday chart data file opened for ZB.20160600.CME_F | 2016-06-06 02:25:57
CTS T4 FIX | Received matching security definition for symbol UB.20160600.CME_F. Subscribing to data. | 2016-06-06 02:25:57
CTS T4 FIX | Received 1 security definitions for underlying symbol UB | 2016-06-06 02:25:57
CTS FIX Historical Data socket (8) | SSL connection established. | 2016-06-06 02:25:58
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:25:58
CTS T4 FIX | Sending security definition request for symbol uB.20160900.CME_F | 2016-06-06 02:25:58
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:25:58
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:25:58
Symbol Error - uB.20160900.CME_F is unknown, unavailable, or improperly formatted. Security definition not found | 2016-06-06 02:25:58
CTS T4 FIX | Received 0 security definitions for underlying symbol uB | 2016-06-06 02:25:58
CTS FIX Historical Data: Sending the Logon message. | 2016-06-06 02:25:58
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:25:58
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:25:58
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:25:58
SC DTC Data | Received logon response. | 2016-06-06 02:25:58
SC DTC Data | Server Name: SC Realtime Server. | 2016-06-06 02:25:58
SC DTC Data | Server protocol version: 7. Client protocol version: 7 | 2016-06-06 02:25:58
SC DTC Data | Successfully connected. | 2016-06-06 02:25:58
SC DTC Data | Restarting real-time data updates for symbol: GBPCAD | 2016-06-06 02:25:58
SC DTC Data | Restarting real-time data updates for symbol: USDCAD | 2016-06-06 02:25:58
CTS FIX: Requesting Open Orders for account: 45* | 2016-06-06 02:25:58
CTS FIX Historical Data: Connected to Historical data server. | 2016-06-06 02:25:58
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-09 00:00:00 to 2015-12-09 00:00:00 (US Central Time). | 2016-06-06 02:25:58
CTS FIX: Received Account List collateral report. | 2016-06-06 02:25:59
GBPCAD [M] Weekly #7 | Reloading chart. | 2016-06-06 02:25:59
HD Request # 7 | Total records received: 0 | 2016-06-06 02:25:59
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-10 00:00:00 to 2015-12-10 00:00:00 (US Central Time). | 2016-06-06 02:25:59
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:25:59
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:25:59
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:25:59
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-11 00:00:00 to 2015-12-11 00:00:00 (US Central Time). | 2016-06-06 02:25:59
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-12 00:00:00 to 2015-12-12 00:00:00 (US Central Time). | 2016-06-06 02:25:59
CTS T4 FIX | Sending security definition request for symbol ZB.20160600.CME_F | 2016-06-06 02:25:59
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-13 00:00:00 to 2015-12-13 00:00:00 (US Central Time). | 2016-06-06 02:25:59
CTS T4 FIX | Received matching security definition for symbol ZB.20160600.CME_F. Subscribing to data. | 2016-06-06 02:26:00
CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2016-06-06 02:26:00
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:00
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-14 00:00:00 to 2015-12-14 00:00:00 (US Central Time). | 2016-06-06 02:26:00
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-15 00:00:00 to 2015-12-15 00:00:00 (US Central Time). | 2016-06-06 02:26:00
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-16 00:00:00 to 2015-12-16 00:00:00 (US Central Time). | 2016-06-06 02:26:00
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-17 00:00:00 to 2015-12-17 00:00:00 (US Central Time). | 2016-06-06 02:26:00
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:01
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-18 00:00:00 to 2015-12-18 00:00:00 (US Central Time). | 2016-06-06 02:26:01
CTS T4 FIX | Sending security definition request for symbol ZB.20160900.CME_F | 2016-06-06 02:26:01
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-19 00:00:00 to 2015-12-19 00:00:00 (US Central Time). | 2016-06-06 02:26:01
CTS T4 FIX | Received matching security definition for symbol ZB.20160900.CME_F. Subscribing to data. | 2016-06-06 02:26:01
CTS T4 FIX | Received 1 security definitions for underlying symbol ZB | 2016-06-06 02:26:01
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-20 00:00:00 to 2015-12-20 00:00:00 (US Central Time). | 2016-06-06 02:26:01
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-21 00:00:00 to 2015-12-21 00:00:00 (US Central Time). | 2016-06-06 02:26:01
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:02
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-22 00:00:00 to 2015-12-22 00:00:00 (US Central Time). | 2016-06-06 02:26:02
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-23 00:00:00 to 2015-12-23 00:00:00 (US Central Time). | 2016-06-06 02:26:02
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-24 00:00:00 to 2015-12-24 00:00:00 (US Central Time). | 2016-06-06 02:26:02
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-25 00:00:00 to 2015-12-25 00:00:00 (US Central Time). | 2016-06-06 02:26:02
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:03
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-26 00:00:00 to 2015-12-26 00:00:00 (US Central Time). | 2016-06-06 02:26:03
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-27 00:00:00 to 2015-12-27 00:00:00 (US Central Time). | 2016-06-06 02:26:03
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-28 00:00:00 to 2015-12-28 00:00:00 (US Central Time). | 2016-06-06 02:26:03
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-29 00:00:00 to 2015-12-29 00:00:00 (US Central Time). | 2016-06-06 02:26:03
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:04
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-30 00:00:00 to 2015-12-30 00:00:00 (US Central Time). | 2016-06-06 02:26:04
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2015-12-31 00:00:00 to 2015-12-31 00:00:00 (US Central Time). | 2016-06-06 02:26:04
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-01 00:00:00 to 2016-01-01 00:00:00 (US Central Time). | 2016-06-06 02:26:04
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-02 00:00:00 to 2016-01-02 00:00:00 (US Central Time). | 2016-06-06 02:26:04
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:05
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-03 00:00:00 to 2016-01-03 00:00:00 (US Central Time). | 2016-06-06 02:26:05
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-04 00:00:00 to 2016-01-04 00:00:00 (US Central Time). | 2016-06-06 02:26:05
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-05 00:00:00 to 2016-01-05 00:00:00 (US Central Time). | 2016-06-06 02:26:05
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:06
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-06 00:00:00 to 2016-01-06 00:00:00 (US Central Time). | 2016-06-06 02:26:06
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-07 00:00:00 to 2016-01-07 00:00:00 (US Central Time). | 2016-06-06 02:26:06
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-08 00:00:00 to 2016-01-08 00:00:00 (US Central Time). | 2016-06-06 02:26:06
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-09 00:00:00 to 2016-01-09 00:00:00 (US Central Time). | 2016-06-06 02:26:06
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:07
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-10 00:00:00 to 2016-01-10 00:00:00 (US Central Time). | 2016-06-06 02:26:07
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-11 00:00:00 to 2016-01-11 00:00:00 (US Central Time). | 2016-06-06 02:26:07
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-12 00:00:00 to 2016-01-12 00:00:00 (US Central Time). | 2016-06-06 02:26:07
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-13 00:00:00 to 2016-01-13 00:00:00 (US Central Time). | 2016-06-06 02:26:07
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:08
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-14 00:00:00 to 2016-01-14 00:00:00 (US Central Time). | 2016-06-06 02:26:08
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-15 00:00:00 to 2016-01-15 00:00:00 (US Central Time). | 2016-06-06 02:26:08
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-16 00:00:00 to 2016-01-16 00:00:00 (US Central Time). | 2016-06-06 02:26:08
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-17 00:00:00 to 2016-01-17 00:00:00 (US Central Time). | 2016-06-06 02:26:08
CTS FIX: Received Account List collateral report. | 2016-06-06 02:26:09
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:09
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-18 00:00:00 to 2016-01-18 00:00:00 (US Central Time). | 2016-06-06 02:26:09
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-19 00:00:00 to 2016-01-19 00:00:00 (US Central Time). | 2016-06-06 02:26:09
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:10
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-20 00:00:00 to 2016-01-20 00:00:00 (US Central Time). | 2016-06-06 02:26:10
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-21 00:00:00 to 2016-01-21 00:00:00 (US Central Time). | 2016-06-06 02:26:10
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-22 00:00:00 to 2016-01-22 00:00:00 (US Central Time). | 2016-06-06 02:26:10
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-23 00:00:00 to 2016-01-23 00:00:00 (US Central Time). | 2016-06-06 02:26:10
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:11
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-24 00:00:00 to 2016-01-24 00:00:00 (US Central Time). | 2016-06-06 02:26:11
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-25 00:00:00 to 2016-01-25 00:00:00 (US Central Time). | 2016-06-06 02:26:11
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-26 00:00:00 to 2016-01-26 00:00:00 (US Central Time). | 2016-06-06 02:26:11
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:12
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-27 00:00:00 to 2016-01-27 00:00:00 (US Central Time). | 2016-06-06 02:26:12
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-28 00:00:00 to 2016-01-28 00:00:00 (US Central Time). | 2016-06-06 02:26:12
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-29 00:00:00 to 2016-01-29 00:00:00 (US Central Time). | 2016-06-06 02:26:12
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-30 00:00:00 to 2016-01-30 00:00:00 (US Central Time). | 2016-06-06 02:26:12
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:13
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-01-31 00:00:00 to 2016-01-31 00:00:00 (US Central Time). | 2016-06-06 02:26:13
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-01 00:00:00 to 2016-02-01 00:00:00 (US Central Time). | 2016-06-06 02:26:13
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-02 00:00:00 to 2016-02-02 00:00:00 (US Central Time). | 2016-06-06 02:26:13
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-03 00:00:00 to 2016-02-03 00:00:00 (US Central Time). | 2016-06-06 02:26:13
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:14
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-04 00:00:00 to 2016-02-04 00:00:00 (US Central Time). | 2016-06-06 02:26:14
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-05 00:00:00 to 2016-02-05 00:00:00 (US Central Time). | 2016-06-06 02:26:14
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-06 00:00:00 to 2016-02-06 00:00:00 (US Central Time). | 2016-06-06 02:26:14
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-07 00:00:00 to 2016-02-07 00:00:00 (US Central Time). | 2016-06-06 02:26:14
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:15
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-08 00:00:00 to 2016-02-08 00:00:00 (US Central Time). | 2016-06-06 02:26:15
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-09 00:00:00 to 2016-02-09 00:00:00 (US Central Time). | 2016-06-06 02:26:15
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-10 00:00:00 to 2016-02-10 00:00:00 (US Central Time). | 2016-06-06 02:26:15
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-11 00:00:00 to 2016-02-11 00:00:00 (US Central Time). | 2016-06-06 02:26:15
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:16
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-12 00:00:00 to 2016-02-12 00:00:00 (US Central Time). | 2016-06-06 02:26:16
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-13 00:00:00 to 2016-02-13 00:00:00 (US Central Time). | 2016-06-06 02:26:16
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-14 00:00:00 to 2016-02-14 00:00:00 (US Central Time). | 2016-06-06 02:26:16
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 02:26:16
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:26:16
ZB.20160900.CME_F Daily #6 | Reloading chart. | 2016-06-06 02:26:16
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-15 00:00:00 to 2016-02-15 00:00:00 (US Central Time). | 2016-06-06 02:26:16
Zb.20160900.CME_F Weekly #16 | Reloading chart. | 2016-06-06 02:26:17
ZB.20160900.CME_F Weekly #9 | Reloading chart. | 2016-06-06 02:26:17
Zb.20160900.CME_F Daily #1 | Reloading chart. | 2016-06-06 02:26:17
ZB.20160900.CME_F Weekly #14 | Reloading chart. | 2016-06-06 02:26:17
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:17
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-16 00:00:00 to 2016-02-16 00:00:00 (US Central Time). | 2016-06-06 02:26:17
Zb.20160900.CME_F Daily #13 | Reloading chart. | 2016-06-06 02:26:17
ZB.20160900.CME_F Daily #3 | Reloading chart. | 2016-06-06 02:26:17
ZB.20160900.CME_F Weekly #2 | Reloading chart. | 2016-06-06 02:26:17
ZB.20160900.CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:26:17
ZB.20160900.CME_F Daily #8 | Reloading chart. | 2016-06-06 02:26:17
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-17 00:00:00 to 2016-02-17 00:00:00 (US Central Time). | 2016-06-06 02:26:17
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-18 00:00:00 to 2016-02-18 00:00:00 (US Central Time). | 2016-06-06 02:26:17
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-19 00:00:00 to 2016-02-19 00:00:00 (US Central Time). | 2016-06-06 02:26:17
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:18
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-20 00:00:00 to 2016-02-20 00:00:00 (US Central Time). | 2016-06-06 02:26:18
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-21 00:00:00 to 2016-02-21 00:00:00 (US Central Time). | 2016-06-06 02:26:18
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-22 00:00:00 to 2016-02-22 00:00:00 (US Central Time). | 2016-06-06 02:26:18
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-23 00:00:00 to 2016-02-23 00:00:00 (US Central Time). | 2016-06-06 02:26:18
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:19
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-24 00:00:00 to 2016-02-24 00:00:00 (US Central Time). | 2016-06-06 02:26:19
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-25 00:00:00 to 2016-02-25 00:00:00 (US Central Time). | 2016-06-06 02:26:19
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-26 00:00:00 to 2016-02-26 00:00:00 (US Central Time). | 2016-06-06 02:26:19
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-27 00:00:00 to 2016-02-27 00:00:00 (US Central Time). | 2016-06-06 02:26:19
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:20
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-28 00:00:00 to 2016-02-28 00:00:00 (US Central Time). | 2016-06-06 02:26:20
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-02-29 00:00:00 to 2016-02-29 00:00:00 (US Central Time). | 2016-06-06 02:26:20
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-01 00:00:00 to 2016-03-01 00:00:00 (US Central Time). | 2016-06-06 02:26:20
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-02 00:00:00 to 2016-03-02 00:00:00 (US Central Time). | 2016-06-06 02:26:20
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:21
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-03 00:00:00 to 2016-03-03 00:00:00 (US Central Time). | 2016-06-06 02:26:21
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-04 00:00:00 to 2016-03-04 00:00:00 (US Central Time). | 2016-06-06 02:26:21
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-05 00:00:00 to 2016-03-05 00:00:00 (US Central Time). | 2016-06-06 02:26:21
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-06 00:00:00 to 2016-03-06 00:00:00 (US Central Time). | 2016-06-06 02:26:21
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:22
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-07 00:00:00 to 2016-03-07 00:00:00 (US Central Time). | 2016-06-06 02:26:22
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-08 00:00:00 to 2016-03-08 00:00:00 (US Central Time). | 2016-06-06 02:26:22
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-09 00:00:00 to 2016-03-09 00:00:00 (US Central Time). | 2016-06-06 02:26:22
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-10 00:00:00 to 2016-03-10 00:00:00 (US Central Time). | 2016-06-06 02:26:22
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:23
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-11 00:00:00 to 2016-03-11 00:00:00 (US Central Time). | 2016-06-06 02:26:23
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-12 00:00:00 to 2016-03-12 00:00:00 (US Central Time). | 2016-06-06 02:26:23
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-13 00:00:00 to 2016-03-13 00:00:00 (US Central Time). | 2016-06-06 02:26:23
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-14 00:00:00 to 2016-03-14 00:00:00 (US Central Time). | 2016-06-06 02:26:23
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:24
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-15 00:00:00 to 2016-03-15 00:00:00 (US Central Time). | 2016-06-06 02:26:24
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-16 00:00:00 to 2016-03-16 00:00:00 (US Central Time). | 2016-06-06 02:26:24
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-17 00:00:00 to 2016-03-17 00:00:00 (US Central Time). | 2016-06-06 02:26:24
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-18 00:00:00 to 2016-03-18 00:00:00 (US Central Time). | 2016-06-06 02:26:24
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:25
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-19 00:00:00 to 2016-03-19 00:00:00 (US Central Time). | 2016-06-06 02:26:25
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-20 00:00:00 to 2016-03-20 00:00:00 (US Central Time). | 2016-06-06 02:26:25
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-21 00:00:00 to 2016-03-21 00:00:00 (US Central Time). | 2016-06-06 02:26:25
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-22 00:00:00 to 2016-03-22 00:00:00 (US Central Time). | 2016-06-06 02:26:25
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:26
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-23 00:00:00 to 2016-03-23 00:00:00 (US Central Time). | 2016-06-06 02:26:26
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-24 00:00:00 to 2016-03-24 00:00:00 (US Central Time). | 2016-06-06 02:26:26
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-25 00:00:00 to 2016-03-25 00:00:00 (US Central Time). | 2016-06-06 02:26:26
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-26 00:00:00 to 2016-03-26 00:00:00 (US Central Time). | 2016-06-06 02:26:26
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:27
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-27 00:00:00 to 2016-03-27 00:00:00 (US Central Time). | 2016-06-06 02:26:27
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-28 00:00:00 to 2016-03-28 00:00:00 (US Central Time). | 2016-06-06 02:26:27
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-29 00:00:00 to 2016-03-29 00:00:00 (US Central Time). | 2016-06-06 02:26:27
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-30 00:00:00 to 2016-03-30 00:00:00 (US Central Time). | 2016-06-06 02:26:27
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:28
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-03-31 00:00:00 to 2016-03-31 00:00:00 (US Central Time). | 2016-06-06 02:26:28
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-01 00:00:00 to 2016-04-01 00:00:00 (US Central Time). | 2016-06-06 02:26:28
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-02 00:00:00 to 2016-04-02 00:00:00 (US Central Time). | 2016-06-06 02:26:28
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-03 00:00:00 to 2016-04-03 00:00:00 (US Central Time). | 2016-06-06 02:26:28
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:29
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-04 00:00:00 to 2016-04-04 00:00:00 (US Central Time). | 2016-06-06 02:26:29
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-05 00:00:00 to 2016-04-05 00:00:00 (US Central Time). | 2016-06-06 02:26:29
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-06 00:00:00 to 2016-04-06 00:00:00 (US Central Time). | 2016-06-06 02:26:29
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:30
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-07 00:00:00 to 2016-04-07 00:00:00 (US Central Time). | 2016-06-06 02:26:30
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-08 00:00:00 to 2016-04-08 00:00:00 (US Central Time). | 2016-06-06 02:26:30
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-09 00:00:00 to 2016-04-09 00:00:00 (US Central Time). | 2016-06-06 02:26:30
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-10 00:00:00 to 2016-04-10 00:00:00 (US Central Time). | 2016-06-06 02:26:30
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:31
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-11 00:00:00 to 2016-04-11 00:00:00 (US Central Time). | 2016-06-06 02:26:31
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-12 00:00:00 to 2016-04-12 00:00:00 (US Central Time). | 2016-06-06 02:26:31
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-13 00:00:00 to 2016-04-13 00:00:00 (US Central Time). | 2016-06-06 02:26:31
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-14 00:00:00 to 2016-04-14 00:00:00 (US Central Time). | 2016-06-06 02:26:31
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:32
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-15 00:00:00 to 2016-04-15 00:00:00 (US Central Time). | 2016-06-06 02:26:32
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-16 00:00:00 to 2016-04-16 00:00:00 (US Central Time). | 2016-06-06 02:26:32
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-17 00:00:00 to 2016-04-17 00:00:00 (US Central Time). | 2016-06-06 02:26:32
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-18 00:00:00 to 2016-04-18 00:00:00 (US Central Time). | 2016-06-06 02:26:32
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:33
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-19 00:00:00 to 2016-04-19 00:00:00 (US Central Time). | 2016-06-06 02:26:33
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-20 00:00:00 to 2016-04-20 00:00:00 (US Central Time). | 2016-06-06 02:26:33
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-21 00:00:00 to 2016-04-21 00:00:00 (US Central Time). | 2016-06-06 02:26:33
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-22 00:00:00 to 2016-04-22 00:00:00 (US Central Time). | 2016-06-06 02:26:33
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:34
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-23 00:00:00 to 2016-04-23 00:00:00 (US Central Time). | 2016-06-06 02:26:34
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-24 00:00:00 to 2016-04-24 00:00:00 (US Central Time). | 2016-06-06 02:26:34
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-25 00:00:00 to 2016-04-25 00:00:00 (US Central Time). | 2016-06-06 02:26:34
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-26 00:00:00 to 2016-04-26 00:00:00 (US Central Time). | 2016-06-06 02:26:34
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:35
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-27 00:00:00 to 2016-04-27 00:00:00 (US Central Time). | 2016-06-06 02:26:35
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-28 00:00:00 to 2016-04-28 00:00:00 (US Central Time). | 2016-06-06 02:26:35
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-29 00:00:00 to 2016-04-29 00:00:00 (US Central Time). | 2016-06-06 02:26:35
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-04-30 00:00:00 to 2016-04-30 00:00:00 (US Central Time). | 2016-06-06 02:26:35
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:36
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-01 00:00:00 to 2016-05-01 00:00:00 (US Central Time). | 2016-06-06 02:26:36
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-02 00:00:00 to 2016-05-02 00:00:00 (US Central Time). | 2016-06-06 02:26:36
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-03 00:00:00 to 2016-05-03 00:00:00 (US Central Time). | 2016-06-06 02:26:36
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-04 00:00:00 to 2016-05-04 00:00:00 (US Central Time). | 2016-06-06 02:26:36
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:37
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-05 00:00:00 to 2016-05-05 00:00:00 (US Central Time). | 2016-06-06 02:26:37
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-06 00:00:00 to 2016-05-06 00:00:00 (US Central Time). | 2016-06-06 02:26:37
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-07 00:00:00 to 2016-05-07 00:00:00 (US Central Time). | 2016-06-06 02:26:37
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-08 00:00:00 to 2016-05-08 00:00:00 (US Central Time). | 2016-06-06 02:26:37
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:38
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-09 00:00:00 to 2016-05-09 00:00:00 (US Central Time). | 2016-06-06 02:26:38
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-10 00:00:00 to 2016-05-10 00:00:00 (US Central Time). | 2016-06-06 02:26:38
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-11 00:00:00 to 2016-05-11 00:00:00 (US Central Time). | 2016-06-06 02:26:38
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-12 00:00:00 to 2016-05-12 00:00:00 (US Central Time). | 2016-06-06 02:26:38
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:39
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-13 00:00:00 to 2016-05-13 00:00:00 (US Central Time). | 2016-06-06 02:26:39
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-14 00:00:00 to 2016-05-14 00:00:00 (US Central Time). | 2016-06-06 02:26:39
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-15 00:00:00 to 2016-05-15 00:00:00 (US Central Time). | 2016-06-06 02:26:39
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-16 00:00:00 to 2016-05-16 00:00:00 (US Central Time). | 2016-06-06 02:26:39
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:40
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-17 00:00:00 to 2016-05-17 00:00:00 (US Central Time). | 2016-06-06 02:26:40
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-18 00:00:00 to 2016-05-18 00:00:00 (US Central Time). | 2016-06-06 02:26:40
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-19 00:00:00 to 2016-05-19 00:00:00 (US Central Time). | 2016-06-06 02:26:40
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-20 00:00:00 to 2016-05-20 00:00:00 (US Central Time). | 2016-06-06 02:26:40
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:41
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-21 00:00:00 to 2016-05-21 00:00:00 (US Central Time). | 2016-06-06 02:26:41
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-22 00:00:00 to 2016-05-22 00:00:00 (US Central Time). | 2016-06-06 02:26:41
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-23 00:00:00 to 2016-05-23 00:00:00 (US Central Time). | 2016-06-06 02:26:41
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-24 00:00:00 to 2016-05-24 00:00:00 (US Central Time). | 2016-06-06 02:26:41
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:42
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-25 00:00:00 to 2016-05-25 00:00:00 (US Central Time). | 2016-06-06 02:26:42
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-26 00:00:00 to 2016-05-26 00:00:00 (US Central Time). | 2016-06-06 02:26:42
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-27 00:00:00 to 2016-05-27 00:00:00 (US Central Time). | 2016-06-06 02:26:42
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-28 00:00:00 to 2016-05-28 00:00:00 (US Central Time). | 2016-06-06 02:26:42
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:43
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-29 00:00:00 to 2016-05-29 00:00:00 (US Central Time). | 2016-06-06 02:26:43
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-30 00:00:00 to 2016-05-30 00:00:00 (US Central Time). | 2016-06-06 02:26:43
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-05-31 00:00:00 to 2016-05-31 00:00:00 (US Central Time). | 2016-06-06 02:26:43
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-01 00:00:00 to 2016-06-01 00:00:00 (US Central Time). | 2016-06-06 02:26:43
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:44
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-02 00:00:00 to 2016-06-02 00:00:00 (US Central Time). | 2016-06-06 02:26:44
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-03 00:00:00 to 2016-06-03 00:00:00 (US Central Time). | 2016-06-06 02:26:44
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-04 00:00:00 to 2016-06-04 00:00:00 (US Central Time). | 2016-06-06 02:26:44
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-05 00:00:00 to 2016-06-05 00:00:00 (US Central Time). | 2016-06-06 02:26:44
HD Request # 7 | Total records received: 0 | 2016-06-06 02:26:45
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 02:26:45
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 02:26:45
HD Request # 7 | Requesting historical Tick data for TN.XCME_F TN (u16).CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 02:26:45
HD Request # 7 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:26:46
HD Request # 7 | Intraday download COMPLETE for TN.XCME_F TN (u16).CME_F. Completion time: 52s. Unique request ID: 6 | 2016-06-06 02:26:46
Removed historical data download ID 6 | 2016-06-06 02:26:46
Real-time Intraday chart data file updates started for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:26:46
Intraday chart data file opened for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:26:46
HD Request # 9 | Downloading Historical Daily chart data for TN.XCME_F TN (u16).CME_F. Starting date: 2016-06-02. Service: cts | 2016-06-06 02:26:46
HD Request # 9 | Requesting historical Daily data for TN.XCME_F TN (u16).CME_F from date 2016-06-02 to date 2016-06-07 | 2016-06-06 02:26:46
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:26:46
HD Request # 9 | Daily download COMPLETE for TN.XCME_F TN (u16).CME_F. Completion time: 0s. Unique request ID: 7 | 2016-06-06 02:26:46
Removed historical data download ID 7 | 2016-06-06 02:26:46
HD Request # 10 | Downloading Intraday chart data for ZN.20160900.CME_F to the file ZN.20160900.CME_F.scid. Service: cts | 2016-06-06 02:26:46
HD Request # 10 | Download start Date-Time: 2016-06-06 02:25:26.000 | 2016-06-06 02:26:46
HD Request # 10 | Requesting historical Tick data for ZN.20160900.CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 02:26:46
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:26:46
TN.XCME_F TN (u16).CME_F Daily #2 | Reloading chart. | 2016-06-06 02:26:46
TN.XCME_F TN (u16).CME_F Weekly #4 | Reloading chart. | 2016-06-06 02:26:46
TN.XCME_F TN (u16).CME_F Daily #5 | Reloading chart. | 2016-06-06 02:26:46
CTS T4 FIX | Using primary service for historical data for TN.XCME_F TN (u16).CME_F | 2016-06-06 02:26:47
TN.XCME_F TN (u16).CME_F Weekly #8 | Reloading chart. | 2016-06-06 02:26:47
HD Request # 10 | Receiving Intraday data for ZN.20160900.CME_F starting at 2016-06-05 17:00:00 | 2016-06-06 02:26:49
HD Request # 10 | Timestamp of first Intraday data file record written: 2016-06-06 02:25:41 | 2016-06-06 02:26:49
HD Request # 10 | Total records received: 19423 | 2016-06-06 02:26:49
HD Request # 10 | Requesting historical Tick data for ZN.20160900.CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 02:26:49
HD Request # 10 | Requesting historical Tick data for ZN.20160900.CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 02:26:49
HD Request # 10 | Received 19423 records from 2016-06-05 17:00:00 to 2016-06-06 02:26:46 (9.4 hours) and wrote 306 records for ZN.20160900.CME_F | 2016-06-06 02:26:50
Added 5 Time and Sales records to Intraday data file for ZN.20160900.CME_F after download. | 2016-06-06 02:26:50
HD Request # 10 | Intraday download COMPLETE for ZN.20160900.CME_F. Completion time: 3s. Unique request ID: 8 | 2016-06-06 02:26:50
Removed historical data download ID 8 | 2016-06-06 02:26:50
Real-time Intraday chart data file updates started for ZN.20160900.CME_F | 2016-06-06 02:26:50
Intraday chart data file opened for ZN.20160900.CME_F | 2016-06-06 02:26:50
HD Request # 11 | Downloading Intraday chart data for UB.20160600.CME_F to the file UB.20160600.CME_F.scid. Service: cts | 2016-06-06 02:26:50
HD Request # 11 | Download start Date-Time: 2016-06-05 19:20:00.000 | 2016-06-06 02:26:50
HD Request # 11 | Requesting historical Tick data for UB.20160600.CME_F from 2016-06-05 00:00:00 to 2016-06-05 00:00:00 (US Central Time). | 2016-06-06 02:26:50
Chart #7 has tagged chart #5 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
Chart #7 has tagged chart #8 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
HD Request # 11 | Total records received: 0 | 2016-06-06 02:26:50
HD Request # 11 | Requesting historical Tick data for UB.20160600.CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 02:26:50
TN.XCME_F TN (u16).CME_F Weekly #8 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
HD Request # 11 | Receiving Intraday data for UB.20160600.CME_F starting at 2016-06-05 18:40:45 | 2016-06-06 02:26:50
HD Request # 11 | Total records received: 2 | 2016-06-06 02:26:50
HD Request # 11 | Requesting historical Tick data for UB.20160600.CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 02:26:50
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
Chart #12 has tagged chart #11 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
Chart #5 has tagged chart #8 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
ZB.20160900.CME_F 30 Sec #8 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
Chart #3 has tagged chart #2 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
Chart #3 has tagged chart #4 for full recalculation. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
TN.XCME_F TN (u16).CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
HD Request # 11 | Requesting historical Tick data for UB.20160600.CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 02:26:50
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:50
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:50
TN.XCME_F TN (u16).CME_F Daily #5 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:50
HD Request # 11 | Received 2 records from 2016-06-05 18:40:45 to 2016-06-05 19:20:00 (39.3 minutes) and wrote 0 records for UB.20160600.CME_F | 2016-06-06 02:26:51
HD Request # 11 | Intraday download COMPLETE for UB.20160600.CME_F. Completion time: 1s. Unique request ID: 9 | 2016-06-06 02:26:51
Removed historical data download ID 9 | 2016-06-06 02:26:51
Real-time Intraday chart data file updates started for UB.20160600.CME_F | 2016-06-06 02:26:51
Intraday chart data file opened for UB.20160600.CME_F | 2016-06-06 02:26:51
HD Request # 12 | Downloading Intraday chart data for ZB.20160900.CME_F to the file ZB.20160900.CME_F.scid. Service: cts | 2016-06-06 02:26:51
HD Request # 12 | Download start Date-Time: 2016-06-06 02:25:26.000 | 2016-06-06 02:26:51
HD Request # 12 | Requesting historical Tick data for ZB.20160900.CME_F from 2016-06-06 00:00:00 to 2016-06-06 00:00:00 (US Central Time). | 2016-06-06 02:26:51
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F 30 Sec #11 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
TN.XCME_F TN (u16).CME_F Daily #2 | Performing a full recalculation because it has been tagged. Chartbook: 10yr Ultra v 10yr.cht | 2016-06-06 02:26:51
Chart #2 has tagged chart #1 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
HD Request # 12 | Receiving Intraday data for ZB.20160900.CME_F starting at 2016-06-05 17:00:00 | 2016-06-06 02:26:51
HD Request # 12 | Timestamp of first Intraday data file record written: 2016-06-06 02:25:45 | 2016-06-06 02:26:51
HD Request # 12 | Total records received: 6872 | 2016-06-06 02:26:51
HD Request # 12 | Requesting historical Tick data for ZB.20160900.CME_F from 2016-06-07 00:00:00 to 2016-06-07 00:00:00 (US Central Time). | 2016-06-06 02:26:51
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:51
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:52
HD Request # 12 | Total records received: 6872 | 2016-06-06 02:26:52
HD Request # 12 | Requesting historical Tick data for ZB.20160900.CME_F from 2016-06-08 00:00:00 to 2016-06-08 00:00:00 (US Central Time). | 2016-06-06 02:26:52
ZB.20160600.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
Chart #1 has tagged chart #3 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
Chart #1 has tagged chart #4 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
Chart #1 has tagged chart #6 for full recalculation. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
HD Request # 12 | Received 6872 records from 2016-06-05 17:00:00 to 2016-06-06 02:26:19 (9.4 hours) and wrote 56 records for ZB.20160900.CME_F | 2016-06-06 02:26:52
HD Request # 12 | Intraday download COMPLETE for ZB.20160900.CME_F. Completion time: 2s. Unique request ID: 10 | 2016-06-06 02:26:52
Removed historical data download ID 10 | 2016-06-06 02:26:52
Real-time Intraday chart data file updates started for ZB.20160900.CME_F | 2016-06-06 02:26:52
Intraday chart data file opened for ZB.20160900.CME_F | 2016-06-06 02:26:52
HD Request # 13 | Downloading Intraday chart data for uB.20160900.CME_F to the file uB.20160900.CME_F.scid. Service: cts | 2016-06-06 02:26:52
HD Request # 13 | Download start Date-Time: 2016-06-03 15:59:59.000 | 2016-06-06 02:26:52
HD Request # 13 | Error downloading historical Intraday data for uB.20160900.CME_F. Security definition not found | 2016-06-06 02:26:52
HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for uB.20160900.CME_F | 2016-06-06 02:26:52
HD Request # 13 | Intraday download COMPLETE for uB.20160900.CME_F. Completion time: 0s. Unique request ID: 11 | 2016-06-06 02:26:52
Removed historical data download ID 11 | 2016-06-06 02:26:52
Real-time Intraday chart data file updates started for uB.20160900.CME_F | 2016-06-06 02:26:52
Intraday chart data file opened for uB.20160900.CME_F | 2016-06-06 02:26:52
uB.20160600.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
ZB.20160600.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:52
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:52
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:52
Chart #5 has tagged chart #10 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:52
Chart #5 has tagged chart #8 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:52
Chart #5 has tagged chart #9 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:52
ZB.20160600.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: M6 BoB.cht | 2016-06-06 02:26:52
Chart #7 has tagged chart #5 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:52
Chart #11 has tagged chart #3 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:52
Chart #11 has tagged chart #4 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:52
Chart #11 has tagged chart #9 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:52
Chart #1 has tagged chart #3 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #1 has tagged chart #4 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #1 has tagged chart #6 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
uB.20160900.CME_F 60 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #2 has tagged chart #1 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #4 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Daily #8 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
Chart #8 has tagged chart #10 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
Chart #8 has tagged chart #14 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
Chart #8 has tagged chart #6 for full recalculation. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Daily #6 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F 120 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #14 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Daily #3 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse and bonds.cht | 2016-06-06 02:26:53
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F 30 Sec #5 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #5 has tagged chart #10 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #5 has tagged chart #8 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
Chart #5 has tagged chart #9 for full recalculation. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F 120 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: bond spreads reverse.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F 30 Sec #1 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:53
ZB.20160900.CME_F Weekly #9 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:54
uB.20160900.CME_F 60 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: BoB.cht | 2016-06-06 02:26:54
HTTP connection to ds01.ddfplus.com:80 (4) | Closed. No error. | 2016-06-06 02:26:57
HTTP connection to ds01.ddfplus.com:80 (4) | Shutdown and closed. | 2016-06-06 02:26:57
[2016-06-06 09:47:13]
We think the problem is you are using the incorrect case in the symbol TN.XCME_F TN (u16).CME_F. Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_ChartDataFiles.html#CorrectingSymbolLetterCase
Also, you really should follow these instructions to speed up the historical Intraday data downloading:
https://www.sierrachart.com/index.php?page=doc/doc_DataSourceSettings.php#ReducingMaximumHistoricalIntradayDaysToDownload1Tick
[2016-06-06 11:57:38]
Meritus - Posts: 164
I have followed the steps above and I thought the issue was resolved, however, the intraday chart for the above symbol is NOT updating at all. I have tried reloading data, deleting and downloading, opening a new chart etc.
http://www.sierrachart.com/image.php?Image=1465214149707.png
[2016-06-06 12:51:16]
Also the ZB Sep 16 contract is not updating in real time. Can you please advise as a matter of urgency. Thanks
[2016-06-06 16:54:10]
These questions have been answered in your other Support Request.
