Date/Time: Sat, 04 Jan 2025 07:20:44 +0000
decimal place for euro 6E using CTS data
View Count: 1072
[2016-06-06 02:18:04]
navigator - Posts: 27
How do I adjust the decimal place for the 6E using CTS data? It shows 11.xxxx instead of 1.xxxx Thanks
[2016-06-06 04:20:54]
We are checking on this now.
[2016-06-06 04:27:56]
We do not see this problem for that symbol:
http://www.sierrachart.com/image.php?Image=1465187255795.png
Therefore, follow the instructions here to update the symbol settings:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings
After this is done, then follow these instructions:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps
If you still have a problem we need to see an image of the chart showing what you are seeing.
