Date/Time: Sat, 04 Jan 2025 07:05:13 +0000
Candlestick Width ACSIL
View Count: 1132
[2016-06-05 08:53:55] |
User96015 - Posts: 55 |
Dear sir, I need to build a study which plots a custom chart. I need to plot some candlesticks with different widths. I have seen that Bid Ask Chart Type plots candlesticks with different widths, but I' m not able to find the same variable for acsil. How can I do it?Is there a variable which controls the width of candlesticks for each bars? Thx in advance. Bye. |
[2016-06-06 09:31:54] |
The only way to accomplish this is to set sc.GraphDrawType = GDT_CANDLE_VOLUME_BAR. Use the sc.Subgraph[SC_VOLUME].Data[] array to control the width of the candlestick. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-06-06 09:33:04
