Date/Time: Sat, 04 Jan 2025 07:20:28 +0000
sc.ReconnectToExternalServiceServer taking long
View Count: 669
[2016-06-01 17:33:06] |
User754985 - Posts: 109 |
For some reason sc.ReconnectToExternalServiceServer takes perceptibly longer than doing a manual disconnect-connect. The "Waiting to reconnect" status can be seen for 10-20sec, before anything happens. I of course know that this command only sets a flag, and therefore "return" from the study function immediately after it. |
[2016-06-01 17:55:36] |
We tested this and it took three seconds as expected: IQFeed | Disconnected. | 2016-06-01 13:54:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-06-01 13:54:41 IQFeed | Connecting. | 2016-06-01 13:54:44 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-06-01 20:49:34] |
Hmmm...I retested it separately and it does indeed reconnect as smooth as silk..
