Date/Time: Sat, 04 Jan 2025 07:07:13 +0000
Set As Independent Volume Profile for TPO Chart
View Count: 1166
[2016-06-01 16:09:25]
Robson - Posts: 76
it does not work properly with CTS T4, showing more range volume than "regular trading session" also volume bars do not change properly (for example VPOC have 23k volume and with this option it showing 55k).
[2016-06-01 17:07:14]
Are you setting that Volume by Price study Input to Yes on a TPO Profile chart?
[2016-06-01 20:41:57]
Robson - Posts: 76
yes, I see volume profile but volume bars are incorrect.
Date Time Of Last Edit: 2016-06-01 20:43:19
[2016-06-01 22:07:47]
We tested that setting and we do not see any problem. We need you to follow the instructions here:
To provide a single chart with the configuration where you see this problem and also describe what we should be looking for. Because this is very vague what you are saying.
[2016-06-02 01:50:14]
joeroma - Posts: 43
I had the same problem during real time during the day ssssion (Pacific Time) but while reviewing the charts after hours it seems fine. I'll see what it is like tomorrow.
I also noticed that it displays the total volume at each price level only to the left of the volume profile. When I tried to change the input setting Right Align Volume Bars to No it simply changes it back to Yes when I click Apply.
[2016-06-02 02:06:27]
That is the wrong setting. You need to set Align Volume Numbers to Base of Volume Bars to yes.
[2016-06-02 09:15:49]
Robson - Posts: 76
hope this would help.
Private File
[2016-06-06 01:29:19]
We are doing some testing now of this. However, due to a recent change we do not think we are seeing the same Volume by Price study settings that you have set.
What is the Volume Graph Period Type set to?
[2016-06-06 04:16:21]
No need to provide further information, we think we got the problem resolved. We did find a minor problem and corrected that.
