Date/Time: Sat, 04 Jan 2025 07:10:33 +0000
Transact DOM and SC autotrading
View Count: 755
[2016-06-01 15:59:36]
@sstfrederik - Posts: 404
I am conducting some research on an autotrading development issue.
Would like to know if my understanding is correct. If i would use transact AT software as my trading DOM and SC as my charting software. Will autotrades that initiate in SC be visible in the AT DOM? Will any interaction with these orders in AT be available in the orderbook of SC? If an order would be manually changed in AT is this also reflected in SC?
I reckon one would need to use the SC DOM for order interaction with these trades, so the autotrade strategy can observe this interaction.
Thanks in advance for any insights.
[2016-06-01 18:07:17]
Yes.
Yes.
Yes.
However, Sierra Chart has no control over any of the above. So if there is a problem, you will need to ask TransAct support about this.
Date Time Of Last Edit: 2016-06-01 19:00:56
[2016-06-01 18:22:05]
Thanks.
So the internal orderid of these orders can be used in SC to detect a manual price change of a stop or target order that was altered in AT, but originally originated as an auto trade in SC?
Date Time Of Last Edit: 2016-06-01 18:33:09
[2016-06-01 19:01:34]
Yes this is correct.
