Date/Time: Sat, 04 Jan 2025 07:06:43 +0000
Forex volume data
View Count: 1828
[2016-06-01 15:03:57] |
User83585 - Posts: 8 |
I am not getting a consistent volume feed for about a week now. The bar height suddenly reduces down to around 1/10th of size and so scaling makes these small bars impossible to read. These are not low volume bars in quiet hours, for example this morning during the London session 8.30-9.30am and New York session 14 - 14:30 hrs just to quote two. Many thanks.
[2016-06-01 17:17:10] |
We see you are using the LMAX demo service. Therefore, refer to: LMAX Trading Service: Differences Between LMAX Live and Demo Data Feeds If you are just using FXCM you will not have this problem but you need to re-download the data with incorrect Volume data by following the instructions in help topic 2.1.2: https://www.sierrachart.com/index.php?page=doc/helpdetails2.html#h2.1.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
