Date/Time: Sat, 04 Jan 2025 07:15:40 +0000
Sub-instance will not re-download data
View Count: 767
[2016-06-01 12:09:36] |
phaedonk - Posts: 352 |
Sub-instance is connected to main instance Sub-instance has an open chartbook that includes forex symbols that are not open in a chart in the main instance If data is missing (say a few hours data in EURCAD) in the sub-instance chart, then no matter if I select "Delete and download data" or "Delete All data and download" the missing data will not be downloaded. It will appear to be, (green Historical download complete) but all it will have done is to re-load the data from the main instance (which has data missing, and no way to regain it, as the symbols are not open in a chartbook). This probably is the case for all kinds of symbols? EDIT:In general, it would be good if there was a way for SC to automatically check the downloaded data integrity, i.e. if data is missing where it shouldn't be. It is quite difficult to keep on top of this manually when there is a multitude of symbols being tracked To solve the problem above I had to load all of the symbols in the main instance and select for each of them "delete and download data". And then remove them one by one. Date Time Of Last Edit: 2016-06-01 12:15:16
[2016-06-01 18:03:11] |
We understand this. We will see how to improve upon this. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_DTCServer.php#HistoricalDataAndMissingData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
