Date/Time: Sat, 04 Jan 2025 06:58:07 +0000
Spreadsheet data access
View Count: 886
[2016-05-31 17:36:27]
Willson - Posts: 176
Is there a way to run a non SC spreadsheet program and access cell data in SC spreadsheet in real time? Can spreadsheet cell data be outputed to a history file that can be used by another program? The purpose is to do separate statistical analysis on the cell data.
Thankyou for info
[2016-05-31 18:19:43]
Yes.
Make sure you are on the current version of Sierra Chart.
You can use this command on the Edit menu:
http://www.sierrachart.com/index.php?page=doc/doc_EditMenu.html#ExportBarStudyDataToTextFile
We are still doing some work with the number formatting actually written to the file with that command but as it is now it is fine. This command has to be manually selected so it is not real time.
You can also use this study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s182
Date Time Of Last Edit: 2016-05-31 18:20:59
