Date/Time: Sat, 04 Jan 2025 07:16:49 +0000
No connection for Sierra Chart
View Count: 673
[2016-05-31 15:10:50]
User377131 - Posts: 1
I got the message in the message log as pasted as below
HTTP connection to www.sierrachart.com:80 (4) | Shutdown and closed. | 2016-05-31 09:50:57
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-05-31 09:50:58
HTTPS connection to www.sierrachart.com:443 (3) | Connection gracefully closed by remote side. | 2016-05-31 09:50:58
HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-05-31 09:50:58
HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-05-31 09:50:58
Would like to check why the connection will be closed by remote side?
[2016-05-31 16:31:06]
This is normal and expected. This indicates the connection to the Sierra Chart server.
The connection to the Sierra Chart server is only needed temporarily.
