Date/Time: Sat, 04 Jan 2025 07:09:53 +0000
Horizontal line Non-Extended Tool Suggestion
View Count: 809
[2016-05-31 11:20:30] |
User723043 - Posts: 11 |
Hi all, in the "Horizontal Line Non-Extended" tool, It would be very useful to be able to choose "Use start time" and "Use end time" in the configuration panel (as well as for the "Rectangle" tool), to be able to "save" some Horizontal line configurations that draw automatically some resistance / support lines with fixed term applies only to specific moments such as the next day's session or the next RTH only etc, etc. I hope that this suggestion can be found helpful. |
[2016-05-31 16:58:46] |
As a general rule none of the drawing tools allow you to preconfigure times for the anchor points. These are set when using the drawing tool. We would not haphazardly add this to any drawing tool. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-05-31 16:59:09
